Stock Bottom End Dyno#s For LT1 N/A 93 Octane and on E85
Old 04-09-2008, 08:20 AM
  #31
Colin91Z's Avatar
Originally Posted by LPE Z convt
The car had to be retuned Diffrent air fuel ratio @WOT. IMO with out a proper tune i don't think you will see very good results. I have an E85 tune and a93 octane tune for my car i just switch tunes. The car needs more fuel and timing for E85 to work properly.. Supercharged, turbo and high compression cars will see the most gains from E85.
Chris
Thanks for clearing that up
Next question, how did you get Joe O to grind a cam for you? I thought he wasn't doing that anymore
Colin91Z is offline
Old 04-09-2008, 09:08 AM
  #32
'94 Bad A Z28's Avatar
This combo has been in my car for about 4 years and still starts everyday.
Reading owns you.
'94 Bad A Z28 is offline
Old 04-09-2008, 09:14 AM
  #33
MichiganSkip's Avatar
Chris
Did you have to do anything to the fuel system for the E85? I know alky likes to eat up seals and stuff and on a carbed motor you have to change out to an alky carb.
MichiganSkip is offline
Old 04-09-2008, 11:17 AM
  #34
marshall93z's Avatar
Originally Posted by '94 Bad A Z28
Reading owns you.
It owns a LOT of people!
marshall93z is offline
Old 04-09-2008, 03:10 PM
  #35
chads97z's Avatar
i personally gained 52HP and 87Ft. Tq. by converting to E85 and having my car dyno tuned for it...
dyno tune on 91
433RWHP @ 5900RPM
405RWTQ @ 3200RPM
Dyno Tune on E85
486RWHP @ 5800RPM
492RWTQ @ 3000RPM
chads97z is offline
Old 04-09-2008, 04:22 PM
  #36
Colin91Z's Avatar
dyno tune on 91
433RWHP @ 5900RPM
405RWTQ @ 3200RPM
Dyno Tune on E85
486RWHP @ 5800RPM
492RWTQ @ 3000RPM
Thats pretty impressive, what all did you have to change to run E85?
Any downsides to the swap? (other than limited E85 availability)
Colin91Z is offline
Old 04-09-2008, 04:23 PM
  #37
Colin91Z's Avatar
Reading owns you.
Oops....it sure does
Colin91Z is offline
Old 04-09-2008, 05:21 PM
  #38
11secgen's Avatar
*edit
,reading just owned me too!
11secgen is offline
Old 04-09-2008, 06:36 PM
  #39
tireburnin's Avatar
dyno tune on 91
433RWHP @ 5900RPM
405RWTQ @ 3200RPM
Dyno Tune on E85
486RWHP @ 5800RPM
492RWTQ @ 3000RPM
I not ready to call BS, but a lot of that looks a bit iffy.
Where did you dyno? Who did your dyno tune? Where did you run the times in your sig? When did you run them? What does your car look like?
I race at Barona and Qualcomm an average of 2 times a month and have NEVER seen a car with your setup. I have never even heard of a car with this setup.
And I know there are limited places to buy E85 in San Diego. Where are you buying?
tireburnin is offline
Old 04-09-2008, 06:54 PM
  #40
SS MPSTR's Avatar
x2.
SS MPSTR is offline
Old 04-09-2008, 09:12 PM
  #41
chads97z's Avatar
1/4 mile times in LACR (Palmdale, CA)
Dyno Tune done by Bob Jennings Dyno in Sepluveda, CA (San Fernando Valley - Los Angeles)
downside: 91 octane: 240miles tank / e85: 190miles tank
camaro is black 97 SS w/ a real LT4 engine, heads, intake
(a FACTORY LT4) just has a salvaged title and had the 6speed replaced w/ a 4L65 when the 6speed blew up
the only place in CA you can get E85 is pearson ford @ 15fwy/el cajon bl that i can find - anyone else have other sources?
and since regular gas is E10 - the fuel system should be fine w/ E85 - no problems yet - been running for about 2 years
**EDIT: times and dyno in signature are my best/top numbers / DynoShop in Santee about 1 year ago had me @ 463RWHP w/ same setup that i got me 486RWHP in LA / Last dyno was about 1 year ago, last time i ran was about 18 months ago**
chads97z is offline
Old 04-09-2008, 09:19 PM
  #42
SS MPSTR's Avatar
Impressive.
SS MPSTR is offline
Old 04-09-2008, 09:34 PM
  #43
chads97z's Avatar
Originally Posted by SS MPSTR
Impressive.
Thank You - cant say stock bottom end though... and my heads flow 304/235cfm... when flowbenched
chads97z is offline
Old 04-09-2008, 09:41 PM
  #44
tireburnin's Avatar
Sounds like a badass setup. I actually worked on permiting that dealership for E85 and that is one of the only places you can buy it at the pump. There are a couple of others in the process, but I don't think they are pumping yet.
Your car sounds like a good run for my car. If you ever decide to run at the Q or Barona, send me a PM. I'd love to run another Fbody that runs good numbers.
Sorry for almost calling BS on you, the car/times/setup just seemed a bit much for a new member with 15 posts that I had never seen at the track before. Good luck with it.
Old 04-09-2008, 09:46 PM
  #45
SS MPSTR's Avatar
Humongous valves too. What cam are you running? Assuming SR with the shaft mounts....
SS MPSTR is offline
Quick Reply: Stock Bottom End Dyno#s For LT1 N/A 93 Octane and on E85
