Stock harmonic balancer
Old 01-12-2009, 08:45 PM
  #16
ak95ta's Avatar
Originally Posted by dr97z
He also says that the intake manifold pressure drops when he mashes the gas. I've been told either theres an air intake restriction or valves could be to tight and not seating all the way and causing compression loss.
Go get your car from him, the above statment makes no sense. How long has he been tuning?
Edit:BadAssed beat me too it..
ak95ta is offline
Old 01-12-2009, 08:54 PM
  #17
dr97z's Avatar
He says it sits at about 96kpa then when he hits it, it falls to 89kpa. He's been tuning for a while, but Bryan from PCMFORLESS said that it could be the valves to tight statement.
dr97z is offline
  #18
WS6T3RROR's Avatar
It does make sense, if you build vacuum under wot (from a restriction) the kpa value will drop because its absolute pressure you're dealing with.
WS6T3RROR is offline
Old 01-12-2009, 08:57 PM
  #19
dr97z's Avatar
This is Bryan's email
that is a big cam, but if he is seeing MAP pressure variations (basically seeing Vacuum) there could be some inlet restrictions choking it, or the valve lash could be too tight not allowing all the valves to seat and blowing off compression.
thanks,
Bryan
dr97z is offline
Old 01-12-2009, 08:59 PM
  #20
dr97z's Avatar
What do you guys think about the valve lash?
Just so you know, I have Morel lifters and I went 1/4 turn past 0 lash.
dr97z is offline
Old 01-12-2009, 09:58 PM
  #21
WS6T3RROR's Avatar
1/4 turn 1/2 turn shouldnt make a diddle worth of difference, I have seen people swear up and down that it does. What makes a difference is how good you are at finding zero lash some people are just not good at it. If you think thats the problem, set the lash with the engine running.
I'd be looking at fuel pressure, air fuel ratio, and a datalog of what the engine was doing during a run, your tuner has the logs because he is talking about absolute pressure and kpa. I have the software and will take a look at it if he will email the logs to you. The dyno graph will probably tell the story though.
On your bad optis, have you taken them apart and made sure the rotor screws are still tight, that is an issue i have seen many times. Also check the harness out to the opti and the condition of the wires all the way back to the pcm.
Might have them pull the filter off to see if thats the problem. What kind of throttle body is on the engine? How much power or airflow (grams/sec from maf) are we talking about here?
Old 01-12-2009, 10:18 PM
  #22
dr97z's Avatar
Fuel pressure is solid after getting rid of the aeromotive AFPR. Air Fuel ratio, I'm assuming is good, since that's usually the first thing he gets right when tuning. I'll try to get the logs from him and the graph.
As far as opti sparks. The last one I had on there was a dynatech with the old motor. This one is a brand new MSD and I did take the rotor screws out and put thread lock on like everyone suggests. Harness is brand new with MSD. As far as I could tell the wiring back to the PCM was good, because I did check it out before starting the new motor.
It's a Holley throttle body 58mm. Don't have the answers to your other ?'s. I will email him and see if I can get the info you're requesting.
Thanks for helping out.
dr97z is offline
Old 01-13-2009, 04:13 AM
  #23
SS RRR's Avatar
So refreshing to read good sense like this!
SS RRR is offline
Old 01-14-2009, 08:26 PM
  #24
dr97z's Avatar
Here's the link to my dyno run, tell me what you guys think is going on.
http://www.cardomain.com/member_page...jpg?544918-014
dr97z is offline
canbaufo
05-25-2015 12:01 PM
DirtyDaveW
03-15-2015 07:01 PM
MyShibbyZ28
02-14-2015 12:05 PM
cyteone
02-07-2015 06:04 PM
smokin5s
07-24-2003 10:47 PM
Quick Reply: Stock harmonic balancer
