stock maf vs. aftermarket maf
A week ago I took my stock MAF sensor off and cleaned it when I put it back on my coolant fans wouldn't kick on. But if I unhooked the MAF the fans would kick on. So I think my MAF might be bad. If the it is bad would it be best to buy a stock piece or aftermarket?
I bored and polished my stock MAF and it works much better. My throttle response is ten times better and the car feels like it pulls much harder.
If you want one like mine, let me know... I can bore these out on the machine we have.
Stock MAF is pretty expensive. I was in the same issue you are in, my stock maf took a dump, and I WAS going to buy a new stock one until I saw the z06 maf conversion at http://www.ls1speed.com its $150 and it comes with the adapter harness. ITS BIG, so you mite have to goto home depot and get a steel clamp adapter if you have a CAI, but its nice, and alot better then spending $200+ for a stock one.
Stock MAFs are cheaper here in Houston. A local parts yard where I buy them from sells them for $45.00 with a 30 day warranty. Try getting any warranty on an electrical part at Autozone.
I also can bore them out for $75.00... so if you want something like that, spending $120.00 is still cheaper than the Z06 MAF and it looks stock with the same benefits.
Although to use the Factory GM Z06 MAF you must either have your PCM programmed for the different MAF flow/Frequency cureves or program it yourself. Not to mention if it fails again.. I go to ANY GM dealership and have a new part for under $100.
Hey DAVID this is a lil off topic....but is your 95 camaro convertable WHITE by any chance...cause if so ive seen you on highway 6 right buy the krogers in sugar land...i was driving a white 95 maro too with the camaroZ28 sticker on top of my windshield...and if that was you your vert, it was down and you sounded like you had some flows on it!!!!
Yep... That would probably be me. It does have a Flow on it. Mostly stock with a few little mods here and there. I am just hitting this car one simple mod at a time.
I live in the Sweetwater area of Sugar Land but work in Spring at a hanger in the airport up here.
yep ive seen ya!! i ahd my girl in the car comming from i think panera bread...very good place and about to get hired there i belive!! i live in missouri city!! well see ya around sometime!! and what car do you usually drive!!!
10-31-2016 11:09 AM
