Stock MAF vs Ported MAF vs Granatelli
#17
Originally posted by InjectedSS
I don't believe that for one second.
ONE I don't have STOCK TUNING, my car is tuned BY ME PERSONALLY to run at 13:1 in WOT. So I know that with my STOCK MAF it runs at 13:1 in WOT. So then when I put the SAME SENSOR at which I was using in my stock MAF in a PORTED HOUSING and then I turn the car on... IMMEDIATELY the BLMS have already seen that something is wrong and they shoot to 160 on each side... Where's before they were at 128, 127 etc. Then when my WOT AFR is normally at 13:1 it is NOW at in the HIGH 14's LOW 15's AFR. So there's no needing to wait like a week or whatever before the computer catches on because it already caught on to something being wrong right off the bat. So then, when I took that SAME SENSOR that just made the car run at like 160 BLM's at idle and part throttle, and put it in a STOCK NON PORTED HOUSING, fire the car up and BOOM the car is at like 160 BLMS for like 10 seconds before it realizes that everything is ok now. Then of course at WOT everything goes back to my normal 13:1
So the numbers don't lie, and I don't belive that it takes no friggin WEEK to learn cause my car shows it learning RIGHT AWAY
My question is.... did you operate the car for even 30 or 40 seconds within the Cell boundaries (RPM and MAP) for Cell 15 BEFORE you ran your retest?
I know the BLM's will start to change immediately.... but since there are 16 different cells defined by MAP and RPM, the BLM's within a Cell can change ONLY when you are actualy operating within the MAP and RPM boundaries for that Cell. And.. you may have altered the Cell boundaries with your custom tuning, but you still have to operate the engine within those boundaries for EACH Cell. When you start it in idle, you are only looking at Cell 16... and yes, the Cell 16 BLM's will start to respond immediately. But Cell 15.... the Cell used for PE mode BLM's when the PCM is adding fuel... will not start to change until you operate the engine above 2,000RPM, and with an engine load corresponding to 80kPa MAP. And yes... I know with your own personal, custom tuning you can alter those boundaries, but you still need to operate the engine under those conditions to change the BLM's.
What say you?
#18
Originally posted by Injuneer
Not sure why you feel you have to get so defensive.... I know you have your own tuning in the car, and I know you have it properly tuned for WOT. That is not relevant to my question.
What say you?
What say you?
What I decided to do in my testing was to use the BLMS as a guide of what was going on in PART THROTTLE & IDLE since using the wideband was kinda inacurate since the computer is always trying to shoot for 14.7:1 and using the BLMS would show me if the computer was trying to ADD or SUBTRACT fuel. For my WOT tuning I decided to use the WIDEBAND since the computer runs in PE MODE and the BLMS are ignored and not used. This way I can get an accurate reading of what was going on in WOT..
When testing first I RESET my computer by pulling the ECM fuse, then I logged my car with the STOCK MAF and noted my BLM's and AFR etc. The results were that the BLMS were around 128 at idle and crusing, and at WOT the AFR was at 13:1 Then I reset the car again and then put in the PORTED ENDS with the same sensor of course, that way there would be NO QUESTION about using a different sensor etc. Then I drove around and I logged with the PORTED ENDS and that's where I noticed that the BLMS did go up to 160 and the AFR did get thrown off as well causing the car to run LEAN LEAN LEAN 15:1 at WOT.
THEN to satisfy my own thinking, I put the STOCK sensor in AGAIN with the NON PORTED ends, then I reset the computer ONE LAST TIME and then drove around the car for a little while and noted that the BLMS were at like 128 crusing and at idle. Not Dead ON 128 but up and down between like 126-128 as normal... Then WITHOUT RESETTING the ECM this time I installed the PORTED ENDS and the started the car and the same thing happens, BLM's go shooting up to 160 at idle and at crusing, and the AFR ran LEAN as heck 15:1 at WOT in the upper RPMS, and running lean at idle as well. But with the computer TRYING to compensate for the lean condition the AFR was around like low 15's high 14's.. BUT the BLMS WERE MAXED at 160, basically PROVING that the MAF readings WERE being thrown off....
Hope this explains thing's a little better Fred
#20
Originally posted by predator
do you think that the z06 maf would do the same thing because i have that on my car and was wondering if mine was screwing up too i think i may put the stocker back on
I am HOPING that granatelli has calibrated their MAF's so that they are ONLY CALIBRATED for the MAF being PORTED, as apposed to the the STOCK MAF's only being calibrated for NOT being ported. Meaning that when GM designed our stock maf's they knew that it would have the dividers in the middle and a screen.. So in turn GM made all their calculations to account for all that... Well HOPEFULLY granatelli has ONLY calibrated their MAF's for being PORTED and NOT having a screen and dividers in the middle.
What I don't want to see is that granatelli MAF's just TRICK the computer to make the car run LEAN, meaning that even though the granatelli mafs are ported out, the reason people are getting more power from them is beacuse granatelli TRICKS the ecm into running leaner, where's with a stock maf you could just do the SAME THING by going into the MAF table's and make the car run leaner even with a stock maf. Im hoping that the power that people gain from granatelli MAF's is simply from the extra air coming in from the maf being ported. So basically the granatelli mafs are
As far as the ZO6 MAF, if someone want's to send me their's I can test it out and send it back no charge of course. Other than that I have no idea.. Maybe I will run into someone locally that has one and I will eventually be able to test it as well... I can't see the ZO6 MAF being a very good mod because doesn't the ZO6 MAF still have the dividers in the middle? Where's a granatelli MAF doesn't have ANYTHING in the middle except the little sensor.
#23
Originally posted by JDMZ28
engineermike - I plan on having my computer tuned again by MADZ28 because I think my car is running a little on the rich side. I have a laptop, a cable, and I can get tuning software. Is it possible for me to record what my car is doing with the laptop, send the file over the internet, have it modified and then sent back to me? I know he can't tune for optimum power because of the lack of a dyno, but he can get the A/F, timing damn close, by looking at the numbers right?
Other than that, what you're suggesting is possible.
And about the ZO6 MAF, the ZO6 MAF tables in the ZO6 computer are different than our LT1 tables, so it IS calibrated differently.
Mike
#24
For my WOT tuning I decided to use the WIDEBAND since the computer runs in PE MODE and the BLMS are ignored and not used. This way I can get an accurate reading of what was going on in WOT.....
I get countless DataMaster and AutoTap logs to look at to try and help people, and its pretty easyu to tell when the PCM was reset before the log was done, because each time the PCM moves to another Cell, it will be at 128, and it will start to respond by adjusting to the O2 sensor feedback. But there are some Cells that don't happen to get used during that particular logging period, and they will stay at 128 because the engine never operated in the range defined by the RPM and MAP. And even if the engine operated in a particular Cell for a few seconds, that is not enough to fully develop the correction when you start getting up to 140 or down to 115.... it takes a while for the PCM to make a small adjustment, watch the short terms (INT's), then make the required next small step on the BLM's. It is not instantaneous. It takes time.
Please read my original post.... I am not faulting what you have done. I noted that your conclusions were predictable. But I was only trying to make sure you used the correct method to produce those results. It appears there is some confusion on hopw the PCM operates in PE mode.... just trying to make sure your method reflected the way it actually works. I'd like to try what you have done myself, but my stock PCM, my MAF sensor and my O2 sensors are long gone.
#25
Also, take a look at the GPS air flow. Stock is around 230 at redline in 2nd gear. With ported MAF ends (with non calibrated/adjusted sensor) you'll most likely find that number dropping down to below 200 for the same conditions.
I did some testing with the Granatelli and found that the gps flow number went up about 5 or stayed the same so that was good. It'll be interesting to see if you get similar results when you test the Granatelli.
#26
HEY I COULD PROBABLY SEND MINE
#27
HA, that's soo funny that you mentioned that Brent cause I forgot to bring that up as well. At idle with my STOCK sensor being NON PORTED the gms per/sec were at like 10-11 and then with the PORTED ENDS it was at like 7-8 gms per/sec. Once again PROVING that porting the MAF DOES screw the calibration up
Sorry for butting in but, My stock computer (never been programed) with my stock MAF (original from factory)
are reporting:
6 grms per second
650 RPMs
194.90 coolant temp
injector pulse 2.80 milliseconds
Barometric presure 4.90 (pretty much Sea Level)
Vacum 20 hg (measured with mechanical vacum gage)
So my point being here is.... It all depends at what RPMs your 10 - 11 grms per/sec are happening. Every car is different and it should be way better to use just one stock test mule and then swap all the MAF sensors and see the results.
Per your post
Lets just get one test mule car perfectly dialed in.... then swap the MAFs on it to see what effect to then have. As for the Stock Ported MAFs my logic dictates that GM calibrated them for the Airflow/temp/air speed/MAF inside Diameter. Anything we do to them will throw the calibration off.
I found out that even for Oxygen sensors they do use the Tubing inner diameter into their calculations.... use the same Oxygen sensor on a "larger diameter tube" and you throw your oxygen sensors readings off calibration. Dont get me wrong the oxygen readings will be still the same but it will detect a less amount of everything due to less velocity in the exhaust tubing.
Check this out:
http://www.uscar.org/consortia&teams...htm#Parameter1
Grab some aspirins before you go in there.... trust me.
Marvin
#28
are reporting:
6 grms per second
650 RPMs
194.90 coolant temp
Per your post
It sounds like My non-ported all stock MAF is screwing the calibration just like Ported MAF is.... What if its not? what if its the other way around? what if my A4 Idles slower than your M6? see my point? and why would two cars with identical "stock" camshafts will be made to idle at diff speeds?
Check this out:
Marvin
are reporting:
6 grms per second
650 RPMs
194.90 coolant temp
Per your post
Check this out:
Marvin
M6's are set to idle higher from the factory than the auto's. I think it has something to do with the torque converter or something like that. Whatever is going on with your car doesnt sound right though.. You sound like you could use a tune that's for sure Especially with that 194 TEMP Yikes dude, sounds like STOCK tuning to me.
#29
DUDE, I was using MY OWN CAR for all these test's
AHHHHHHHHHHHHHGHHH! DUDE!! you got me on that one... I swear I thought I was answering to some other dude replying to your post!.. and I was like wait a minute.. we can't compare across cars for this testing just yet!!! So fair is fair, you got me dude but then I got you too.... read on =)
I was about to say "You think I am an idiot for no reading your asnwer carefully dont you??"
But then I realised you said....
I'll let ya figure out the rest.
The way I see it we are even
Marvin
Ok Ok I am not 100 percent stock. I have the 160* thermo but for this test purpos, I did let the girl --warm up to the ocassion-- if you know what I mean
#30
At that moment I was like NO! REALLY? (grin)
Marvin
Marvin
Either way, anyone with even a STOCK car can benefit from a tune. I don't know if that's what you were getting at....
