Stock Rocker arm limits
Old 02-02-2005, 12:35 PM
  #16
disco192's Avatar
Re: Stock Rocker arm limits
Well there is more to valvetrain control than just spring pressure. The 918s have MUCH lighter total effective mass compared to the 987s and WILL hold RPM better, but its whatever. If you already have the 987s, then use them. They are good springs.
disco192 is offline
Old 02-02-2005, 02:54 PM
  #17
joeSS97's Avatar
I cant understand why you would put a cam in and use the crappy stock rockers.They are known to be out of spec anyhow.I know money is an issue...but I like to TRY and do things right,at least get the roller tipped rockers....end rant.
joeSS97 is offline
Old 02-02-2005, 03:44 PM
  #18
GUMP's Avatar
I run the factory rockers in my Stockers. I go thru the traps at about 7200 rpm and have never had a valve train failure. Last year I tried swapping in a set of Crane 1.5 roller rockers and gained nothing!
Daren
GUMP is offline
Old 02-02-2005, 04:23 PM
  #19
WS Sick's Avatar
The real killer for the stock rockers is spring pressure, too much over 350 pounds and they will have a great chance of failure.
WS Sick is offline
Old 02-02-2005, 10:41 PM
  #20
Capt'n Two Rotors's Avatar
Thanks for the replies guy's. Hey Gump how are you turning 7200? My pcm doesn't have ignition tables past 7k?
Capt'n Two Rotors is offline
Old 02-03-2005, 12:00 AM
  #21
GUMP's Avatar
DFI
GUMP is offline
Old 02-03-2005, 12:03 AM
  #22
I see..
MyShibbyZ28
02-14-2015 12:05 PM
Jason Short
01-19-2015 06:34 PM
1775.Z28
01-11-2015 10:51 AM
BIGCOWL-IMP
12-19-2014 06:59 AM
Brandon Wittmer
12-07-2014 12:15 PM
Quick Reply: Stock Rocker arm limits
