Stock Valve springs w/ CC306 ??
Re: Stock Valve springs w/ CC306 ??
Originally Posted by 96m6lt1
i think i heard the beehives will work,i am from the ol skool so i would just pull the heads and have them done properly,987 springs titanium ret,etc...
Crane 10308 or K-Motion K800 valve springs are good springs for the CC306. The beehive (918) springs will also work well.
why quote me?cause i want to do it correctly!he has many miles on these heads,just toss some springs on there it will be fine!!!! i think i would be concerned with loose guides,or how about making sure the retainer to guide clearance is sufficient.i rather be safe than sorry...
Location: brunswick ohio, small burb south of cleveland
i didnt think you could just put new springs on?? dont they have to be shimmed to make them all the same?? i thought that part was basically limited to the profiessionals?? thanks.
david
david
to be able to check the spring height,possibly shim would be a good thing go to a good machine shop or better yet e-mail lloyd elliot and ask him,he does this every day.....
i'm running EX-612's w/ my cc306 for many miles now and many 6500 rpms pull...they are rated to .600 and the cc306 w/ 1.6 rr does .544 and .576
i just installed them with the heads on the car and everything, didn't check the height, or use shims or anything. no problems yet!
