Striped lugnut bolts ?
Spin the axle until you find enough room behind the lug that will allow it to come out. Pound out the lug bolt with a hammer. Use only enough force to get it out-don't go wild with a big hammer.
Slip the new lug bolt in from the back. On the front, use some washers as spacers and tighten a lug nut on it (use the flat side of the lug nut toward the washer-backwards as to how you normally put it on) to pull the bolt fully into the axle hole.
carguyshu
01-22-2017 11:19 AM
