Stroker guys. What weight oil do you use?
Old 10-29-2003, 03:46 AM
ZBLKHELLRZR's Avatar
Question Stroker guys. What weight oil do you use?
Just wondering what the consensus is for you 383/396's. What a safe all around weight? It's been so long I can't remember what the shop recommended me. 3rd rebuild. I figure 10/30 dino oil unit I hit 3K then switch to mobil syn 10/30.
Thanks.
ZBLKHELLRZR is offline
Old 10-29-2003, 04:04 AM
Moderator
rskrause's Avatar
10W-30 is probably fine for most situations.
Rich Krause
rskrause is offline
Old 10-29-2003, 04:22 AM
S.J.S.'s Avatar
Rich Krause
After tons of research, I'm gonna put my motor in this weekend and gonna run 10-30 Amsoil. I would run 10-30 synthetic in any brand except Mobil 1. mobil run apparently tends to run thin in the 10-30w range. Guys go with the 10-40w in Mobile 1. Don't quote me on it. Patman.....the oil researcher did a lot of study time on it. Do a search.
S.J.S. is offline
Old 10-29-2003, 04:27 AM
Patman's Avatar
It's true, Mobil 1 makes one of the thinner 10w30s out there, Redline or Amsoil 10w30 is much thicker at 100C.
Depending on your clearances, you may want to step up to a 10w40 though, something in the 13-14cst at 100C range (a thin to medium 40wt) Many stroker motors also use looser clearances, hence my suggestion for something slightly thicker.
Patman is offline
Old 10-29-2003, 05:16 AM
Thanks for the info guys. My friend runs 5-30 in his 383 which I think is too thin. But he gets away w/ it no problems.
Old 10-29-2003, 06:28 AM
TedH's Avatar
Engine builder should specify the oil. I use 20-50.
TedH is offline
Old 10-29-2003, 09:43 AM
95 Silver TA's Avatar
Rich Krause
I agree with Rich, Thats what my engine builder recommended for my set up and thats what I have been using but I am still using Dyno oil. So far everything works great with almost 20K miles on the motor.
Thx,
Claude
95 Silver TA is offline
Old 10-29-2003, 10:19 AM
Gripenfelter's Avatar
Depends on your bearing clearances. I use 10W40 as recommended by my builder.
Gripenfelter is offline
Old 10-29-2003, 10:38 AM
Agreed.
Winter: 10W-30
Summer w/ 275-shot: 20W-50
Injuneer is offline
Old 10-29-2003, 11:37 AM
94_Camaro_LT-1's Avatar
Engine builder recommened...
Summer 20-50
Winter 10-40
94_Camaro_LT-1 is offline
Old 10-29-2003, 11:48 AM
BigJustinZ28's Avatar
I know my cars not a stroker but its got some mods , I run 20w-50 year round in all my cars and none have ever needed a rebuild although I can get away with that down here in nc cuz it almost never gets below freezing here . I like the oil pressure to be nice and high
BigJustinZ28 is offline
Old 10-29-2003, 12:08 PM
JPSartre12's Avatar
Re: Stroker guys. What weight oil do you use?
Thanks.
I put Mobil 1 10-30 in mine. I'm planning on driving it in the winter here in Michigan and thought it was a good choice. I notice that you're in Germany. Is your car over there with you? If so, you lucky, lucky man. I'd love to cruise the autobahn and take on a few Ducatis and then smoke some MB's and BMW's at stoplights.
There's no substitute for pure raw US powerplants from stoplight to stoplight.
JPSartre12 is offline
Old 10-29-2003, 12:11 PM
tend2609's Avatar
just an FYI, i know most of your engine builders told you what to use and i would follow them but for the rest of us, 5w-30 is the best all around method, 80% of engine wear occures during the first minute of driving. I doo reccomend Syth tho, I use M1 5w-30 in the winter and seeing that it is one of the thinner 10w-30s out there i use it in the summer. It seems to be working just fine, well that an i aviod FRAM filters like the black death, only use Purolator or AcDelco. But that is just me.
tend2609 is offline
Old 10-29-2003, 01:31 PM
Moderator
rskrause's Avatar
I was trying to keep it simple. 10W-30 is fine for most motors/uses. Mine is setup loose with a high oil pressure to cushion the bearings from a big nitrous shot. I use 20W-50 but the car is not used in cold weather and I never put a load on it until the oil is warm.
But 10W-30 is a good all around choice.
Rich Krause
rskrause is offline
Old 10-29-2003, 01:41 PM
PNYKILR's Avatar
Location: Albuquerque,NM--5,600 feet above you sea-level cats
That's what my engine builder told me to use aswell..
PNYKILR is offline
Quick Reply: Stroker guys. What weight oil do you use?
