Stumbling Problem in Great Detail
Old 02-19-2004, 02:53 PM
  #121
ryaskovic's Avatar
Originally posted by Fastbird93
Is it possible to have an internal vacuum leak somehow???
Must be a black car thing.
You could have if the intake manifold is not sealed to the heads well. The intake ports could then suck air and oil from the lifter valley.
RobY
95Z28
ryaskovic is offline
Old 02-19-2004, 02:55 PM
  #122
Fastbird93's Avatar
Hmmm.....that could be getting somewhere. Could it possibly be fine cold then open up when warm??? I doubt what you described is going to be the problem, but it may come down to pulling the intake at some point. I'll keep that in mind.
Fastbird93 is offline
Old 02-25-2004, 12:25 PM
  #123
ryaskovic's Avatar
Any new info Fastbird?
Old 02-25-2004, 04:46 PM
  #124
Fastbird93's Avatar
Nothing new as of yet. They're going to give taking the cat off a shot, but I had it off after the problem started and you could see right through it. It would make sense though, it clogs up as it warms up. That's gonna be embarrassing if that's all it was though. After the cat doesn't work (which I'm fully expecting), they're going to do a compression/leakdown test, so we'll see......
Old 02-26-2004, 08:46 AM
  #125
OffspringZ28's Avatar
Results? any word on the fix? been following this for a while now and chasing my own gremlins down.
OffspringZ28 is offline
Old 02-26-2004, 10:19 AM
  #126
CoUnTryMuZiCZ28's Avatar
Hey fasbird, I have that split Lterms problem (only at idle) im thinkin its the TB, i have a 52 mm BBK... How do i drill it out or W/E?? IAC counts are at like 65-70 so do i need to?
CoUnTryMuZiCZ28 is offline
Old 02-26-2004, 10:58 AM
  #127
got_hp?'s Avatar
this site had the info but it appears to be down right now......check later
got_hp? is offline
Old 02-26-2004, 11:24 AM
  #128
alemans_formula's Avatar
try this
hey bro check it out. i had the same problem that you are having. have you checked for the fire works under the hood. look under the hood at night and look to see if you have any arching on any of your plugs or wires. the reason that i said plugs is because i droped one of my plugs while doing a tune up and the car would stumble and kick when the skip shift kicked in. i changed almost the intire ignition system before thinking to look under the hood. will it turns out that one of my plugs had a hair line crack in it. so you might want to check plugs first
alemans_formula is offline
Old 02-26-2004, 11:34 AM
  #129
try this
hey brother i tried to reply ealier but i guess i clicked on the thread. any ways check it out check for the fire works under the hood. check to see if you can see arching on the plugs or the wires at night. i had a hair line fracture in my #1 plug and the car car would stumble till it got above 2000 rpm. so try that out and tell me how it worked.
Old 02-26-2004, 07:22 PM
  #130
1FstFormulaV8's Avatar
I finally found out what was wrong with my car! I have bad fuel injectors. Not the nozzle themselves, but the electrical connections on the fuel injectors were totally messed up.
Finally I'm so glad that problem is fixed.
I hope you find your solution soon too.
1FstFormulaV8 is offline
Old 02-26-2004, 09:06 PM
  #131
Fastbird93's Avatar
They pulled the cat off today, and were supposed to run it and let me know tomorrow.......
Old 02-27-2004, 05:23 PM
  #132
Fastbird93's Avatar
Well, not that I was holding my breath or anything, but it wasn't the cat. I just got off the phone with FBC, and when I asked if the ran the car, the reply was:
"We ran it earlier without the cat, and it still ran like sh*t."
I swear I'm about to go ballistic on that mofoing car.
Old 03-14-2004, 12:28 PM
  #133
OptiStrikes again!
Well, My Opti crapped again! The rain gutter seal leaked..And since my the front of my car was pointing down..the water trickled down the intake and into my Opti!!! So, I need another.
Great.
Old 03-14-2004, 12:33 PM
  #134
Fastbird93's Avatar
Guess I should update this. On Monday 1 March I get a call from the shop. Dropped compression on #3 and #5. Leakdown was 45% on #5 and 35% on #3. A new 355/custom cam setup is in the works right now from AP Engineering.
Old 03-17-2004, 09:07 AM
  #135
I got my new Opti this morning. I goes in friday. Let us hope this one lasts more than 2 months.
Quick Reply: Stumbling Problem in Great Detail
