Stupid quetion...how do I close the gap on plugs?
I bought some NGK 55 or whatever they are "copper core" plugs
First question is...what should the gap be on them? stock engine
Secondly how do I close the gap...I can open it just fine with the gap measuring tool but I dont know how to close it
Alright I'll shoot for a little less than .05
I think someone said to gap the coppers less .040-.045 on another thread because they wear faster or something
Oh yea...another simple question...I have the gapping device from advanced auto parts, and its a circle looking thing with a edge that progressively gets bigger and bigger. I'm sure you know what i'm talking about...but how do you line up the spark plug edge to read it. The spark plug tip I think can be about .002 big or something and I'm wondering where you read it to know what it measures.
That really doesn't make any sense but if you know what i'm trying to say chime in
Ok i'm a moron
I just did the drivers side and did the 1st plug (the one closest to the headlight) and the 2nd plug (the one just behind it)...but I dropped the wires and i'm not sure which ones go where
Does the wire thats located on the bottom of the group of 4 wires coming off the optispark go to that 1st plug on the engine?
Well, I work with engineers from NGK and Champion on a lot of spark plug related projects since my company builds 12 million engines every year. And when they need to close a gap, they tap the plug on something (carefully!), then reset the gap with a wire gauge. No BS, either, LOL. I even asked them about this once and the guy was laughing when he told me how he did it. Now, I'm not talking about large gap changes, and if you want to go from 50 to 30 or something like that, you want to try to make the ground electrode parallel with the flat end of the center electrode if you can, which can be a little difficult to do with the little bendy tools made to bend the ground strap. Careful not to crack the insulator if you use one of those.
As far as the copper center goes, that is pretty much industry standard construction just because it conducts so well. The electrodes are still some harder metal like tungsten (center) nickel (ground) or else platinum or iridium.
Ok i'm a moron
Engine from front to back driver side 1,3,5,7 now on the distributer, plug 1 goes on the bottom of the distributer, plug 3 goes on the 2ed from the top of the distributar so from bottom to top of the distributer it should be 1,7,3,5.
Hope thats what you was needing.
We did mine without a swivel, no idea how, we had to put the socket on the plug, then an exstenion then the ratchet, of course we then got it stuck and could not get the ratchet out or the socket.
Yea we sorta tried doin that, but it was the last plug we did, and we were losing a lot of blood and decided to stop.
I think a swivel would be perfect, because its not quite as long as the extension and I could move it to an angle so that it wouldn't hit the exhaust manifolds
I think I've heard people taking off the alternator, but we started doin that but figured it was a bad idea because we weren't really touching it when trying to remove the plug.
