Summit Valve Spring Height Micrometer
Can this one be used on the 26918-16 beehive valve springs? I am in need of one but dont want to pay 71.00 for one. Thanks
http://store.summitracing.com/partde...5&autoview=sku
When I did mine, I used a standard valve spring height mic (Pro Tools, I think) but I had to deduct 0.148 in. from all my readings to correct for the amount the beehive retainer sits below the top of the tool. (I measured the recess in the top of the tool with a depth mic to determine the 0.148 in.)
Yes that one will work. As said above you will need to measure the recess at the top and subtract that from the reading to get actual. The Comp "beehive" mic will not work on the LT1 beehive retainers because the valvestem is larger and the retainer won't fit into the gauge. I reamed mine out to be able to use it but save yourself the money and by a standard spring mic.
