Summit X pipe question
For those of you that have a summit x pipe did you get the kit with the other pipes or just the x itself. If the other 4 pipes arent going to be close enough to make work than i will just order the x itself. but i like the mandrel bends of the kit. any input is appreciated
Re: Summit X pipe question
i bought the $100 3" "summit x-pipe kit" (4 mandrel bent legs and x-pipe)
had too purchase collector reducers (3"-3")
bolted up too my Hookers like it was meant too be there
EDIT: i did pull the trans cross member and grind about 4" off of the lip for clearance...did i have too, i dont know but i did it anyway so i didnt have too pull it later
Same here.....Worked like a charm......I had it on there once with the x-pipe like you would normally put it and it worked awesome with stock Torque arm, I changed to Spohn TA and just turned the x around and it went around the ta that way....
