Suspension Questions
I am putting my 9 inch rear in soon and want to do the whole suspension over on my car(stock now). I want to lower the car one inch and put drag springs in the rear. Are the Eibach drag springs they sell in Jegs worth the money? I want the car to get good traction and will sacrifice some handling to get it. I am curious as to what everyone is running and how the ride is, traction, etc. Thanks
I have a 9"rearend with,Spohn Lower Control Arms with Adj. Spherical Rod Ends,Spohn Panhard Bar with Adjustable Spherical Rod Ends, Spohn Pro-Series Rear Drag Sway Bar, and a mofidied Jegs torque arm bar.Still running stock springs. The 9" rear will raise your rear end of your car about 1". My opinion is you don't need to lower your car with this set up, unless you just like the looks.
F'n1996Z28SS
08-23-2023 11:19 PM
Hurin
12-13-2014 07:38 PM
