SVO 30 lbs injectors
Yes, your stock rail clips will work with the SVO 24 or 30# injectors, with no modification or additional parts.
But no, you dont need them. You can run the injectors without clips.
I'm running 30# SVO injectors on my 93. In the past I've used the clips, but at the moment I'm not...
