SVO injector questions
I have a couple of questions about the motorsports injectors. I'm looking at new ones and trying to decide between 30lb and 24lb. I can get them both for the same price, right now I just have bolt on mods, possibly in a year or 2 I might throw a mild cam in the car. You guys think I should go with 30 or would the 24's be sufficient? If i do stick with 24's, would I have to do anything to the computer to compensate for them, or will they act the same as the stockers even though they're motorsports? I have my car tuned by pcmforless, so getting the comp retuned is no big deal, I was just curious.
Re: SVO injector questions
dont sweat replacing injectors yet.
but...
they will bolt right in too the stock harness and rails without issue
with the 30's, you will need the pcm recalibrated for the new injectors
24's might need recalibration also because the SVO injectors are rated at 39psi of pressure at the rail and our cars are rated at 43.5...that could skew some of the "parameters"...someone with more knowledge about that will have a better answer for you then me tho
if you do buy some, get the 30's. they will allow for more growth in the future. its easier too take fuel away then it is too add fuel you cant support
but IMO, since you have 24's stock...i wouldnt worry about changing them even after swapping cams. unless you have proof that the stock injectors are being over worked thru real time data logging
if you look in the 5.0 fuel section of www.gefracing.com you can find the 30's new for $199...thats the cheapest place i've ever seen them online
but...
Well the main reason I'm replacing them is one or more of them is leaking down when she sits. Should have mentioned that in the first post. Thanks for the link, I'll check it out and when I decide I'll most likely get it from them.
stockssn2o
05-25-2015 08:54 AM
Wilson
07-21-2002 05:08 PM
