tb air foil problem
tb air foil problem
I just installed throttle body airl foil on my 94 z today,the acceleration is great but if i dont bring the cars revs up and slip the clutch a bit the car wants to stumble and fall flat on its face from a stop.Have any of you guys encountered this problem with the same item?Could it be that the air foil blocks off some of the air space for the iac motor?
I had the exact same problem after I installed a Holley Air foil. There is either a hole or groove, depending on brand, on the back side of the air foil to let air in for the IAC. I had to take a dremel tool and open up the goove to allow it to flow more air. With my ported heads and cam my car would almost die at stop lights. Opened up the groove and no more problem.
94z28jbw
09-08-2002 03:22 PM
BM93Z
08-22-2002 02:45 PM
turbo_Z
08-19-2002 10:50 PM
