Temp gauge issues
Old 06-13-2011 | 05:10 AM
King Kong28's Avatar
Exclamation Temp gauge issues
My 93 6 speed all stock camaro has me worried when Im driving around and the temperature gauge goes all the way up to the line before the red area; that's when the fans turn on and cool it a little bit, is that normal? If not, what should i do?
Old 06-13-2011 | 05:24 AM
Re: Temp gauge issues
The first fan should turn on at 226*F, the second fan at 235*F. Both those temperatures are near the 3/4 mark, not in the red. The gauge reads a sensor in the drivers side head. The ECM (which controls the fans) reads the temperature with a sensor in the water pump housing. Possibly one of those sensors is defective.
Courtesy of Shoebox:
http://shbox.com/1/4th_gen_tech2.html#ect
Does this happen only when you are driving at higher speeds? If so, is the air dam intact under the front bumper? If its missing, the temp will generally be OK at idle, but will climb steadilly the faster you drive.
Old 06-13-2011 | 05:31 AM
Guest47904's Avatar
Guest
Never liked how hot mine got when I had it. Even though it was at the correct temps, I installed this:
http://www.jegs.com/i/JET+Performanc...60602/10002/-1
Old 06-13-2011 | 02:41 PM
No it generally cools down at high speeds, i just thought it might be overheating.
Old 06-14-2011 | 01:14 AM
Fatdog2's Avatar
You might need to change the coolant.(And the thermostat).
Magenta_Hearts
03-29-2017 08:54 PM
Z28countrymama
01-22-2015 02:50 AM
cmdeshon
12-27-2014 10:06 AM
brentbrowning01
12-16-2014 06:35 AM
ro2207
12-04-2014 06:18 PM
Quick Reply: Temp gauge issues
