tempature climbs after engine is off?
Re: tempature climbs after engine is off?
It's called heat soak and it's perfectly normal. You'll notice it more in the Summer, especially on really hot days, but even in cooler temperatures you'll see the temp. gauge go up and then eventually start going back down as everything cools off. You gotta remember that when you shut your car off there is still a ton of heat in the heads, exhaust manifolds, pistons, etc..., and that heat needs to go somewhere, so it "soaks" into the engnine block and cooling system.
CamaroRSguy
08-19-2002 01:52 PM
pnbarbee
07-09-2002 06:35 AM
