temperature problem
Old 03-28-2007, 08:20 PM
  #16
OBE1 95Z28's Avatar
Sounds like you may have a couple of issues. Bleeding the air out of the coolant system as stated above, and a bad wire/connection to your temp sensor. The temp sensor is located in the driver's side head between spark plugs 1 and 3. If the wire or connection to the sensor is bad, your temp gauge will jump around.
OBE1 95Z28 is offline
Old 03-28-2007, 08:57 PM
  #17
needsize's Avatar
the sensor thing sounds right, as no way it should jump around that fast, I'll check that out tomorrow....
needsize is offline
warmeck
04-27-2015 04:34 PM
Biggiebound
04-21-2015 11:28 PM
MattFick
02-15-2015 10:16 PM
01-23-2015 01:13 PM
Jazsun
12-29-2014 12:14 PM
Quick Reply: temperature problem
