There may be a new lifter option
#17
#18
Just ordered a set from SDPC today, for a 383 Le2
pt sd8689 217.85 /set
Ls7 Lifter preload according to ls1tech, 1 to 1-1/2 turns.
crane did some testing and found that .060" of preload (cold) is best for hp, using (there) lifter. Thats around 1-1/2 turns.. They claim they made 20hp more than using the standard 0.010" (cold)preload setting..
not sure if that applies to these lifters or not
#19
.060" is 1 1/5 turn on 7/16" studs and 1 1/2 turns on 3/8" studs, just in case anyone was wondering.
I'm guessing this would be better since it can keep more pressure on the lobes without losing compression or lift. Any more comments about what applications would require these and how to set them up, Bret?
#22
Wow, I'm glad to see the reception to these. I wasn't sure if I was off my rocker or not when I posted this because I thought someone has got to know about them and mentioned it here.
Whoever had it, thanks for the part number. I was just getting ready to find it.
Mainly, I'm just glad that there's a less expensive but quality alternative now.
#23
#29
OK..I'm trying to figure all this out. I always adjust my valves with the motor running. When I did my CC305 cam with COMP "stock replacement" lifters, I went 1/4 turn past "chatter". Wouldn't 1 turn past zero equal 1 turn past "chatter" with the engine running?
Frank
Frank
#30
At the point where chatter just stops, that should be effectively zero lash.
