There may be a new lifter option
#31
Bret showed these lifters to me when visiting the GM island at PRI last December and I've had them circled in the GMPP catalog and finally purchased a set from Dal (support DAL whenever possible).
Found in the Chevy LS Series section of the GMPP catalog #88958789
Just left of the LS7 Titanium connecting rod at $2736 for a set of 8. Wa!!.
Racing Hydraulic Roller Lifter Kit:
As developed by GM Racing and GM Powertrain
For use in Gen III and Gen IV engines where sustained high rpm's are typical
Special reduced-mass internal components allow for higher limiting speeds with aggressive camshaft designs
Improved valvetrain dynamics and stability will improve horsepower, and high rpm's
Tested to 8000rpm in GM racing applications
Set of 16.
I'm going to give them a try in a stock bottom tree-fiddy later in the spring.
Karl
Set of 16.
Karl
#38
#44
