Is there a way to repair this? (pic)
aw man just get some 1/4 hose and put 2 and 2 together bud thats an easy fix there...if not 1/4 find the size that is the tightest on the plastic tube and put 2 tiestraps on it if it makes you feel comfortable but its not as critical as you may have thought.
Its one of the most broken parts on the Camaros. They are $20 or so through the dealer and $10 on Ebay for an aftermarket one. They need to be spliced on either route and the AC Delco one looks just like the ones on Ebay so its your call.
Thanks jammer...I might just repair it with some hose if I can't find a replacement.
Do you know what its called?
Edit...actually I'm thinking you're referring to the broken plug...that's not what I'm worried about
Thanks alot guys. While the pic is up, does anyone see that oil in the tb port? That port has a hose that goes into the passenger side head. What's up with the oil in there? Normal?
I just found out my pcv valve setup wasn't working (big tear in the hose), so could that have been a cause?
