Are these typical numbers?
#17
Is that graph corrected for the conditions? Usually the correction factor is indicated on the graph somewhere, but i dont see that anywhere. Call the place that did the dyno and ask them to email you a SAE-corrected version of the graph. It will make it a little easier to compare your numbers with other people.
#18
Because as far as I know it has the stock cam in it, I don't hear or otherwise notice any difference, so the guy went with the factory redline. Yes it is corrected, the guy showed me the std vs sae difference on the computer. It doesn't say it on the graph but did on the comp in a pull down tab to select the diff chart to see. So I'm pretty sure this is the SAE corrected version cuz thats the last one we looked at before he printed.
How much do you think the header leak, a pretty bad one (it annoys the hell out of me anyway), affected it?
Someone said headers can net you around 20 hp over stock, thats a good bit, so if I have a leak where the headers meet the y pipe, I'm wondering what kind of difference you think that could make?
#19
Catmaigne
07-14-2015 05:17 PM
gelbza
07-12-2015 08:10 AM
jasonduaine
Exhaust System
03-20-2015 09:00 AM
