Thinking about a cam
Well the opti decided to take a dive on me.
After talking to a pretty fast Supra buddy I was telling him how I am throwing in some long tubes to go with the nitrous and all that. He told me that since I will have the majority of the stuff off for a cam swap with the opti replacement that I should do a cam swap. What do you guys think of an LT4 Hot cam on stock springs and all? I don't want anything crazy because I want to build a motor down the road. Any sugestions or will I be stuck pulling the heads and throwing in new springs and all? Oh and stock heads and a 3.42 gear.
Re: Thinking about a cam
Get a hotcam kit if you want the hotcam, you wont get all the cam without 1.6 RR's and springs to match. They can be had for a bit over $400.
I am still wondering why a Supra guy is telling you what to do with your car? Did he used to own a LT1?
Its not a bad idea though, cams are fun peices of metal.
-Dustin-
-Dustin-
The Supra guy has messed with domestics quiet a bit along with the LS1/LT1 stuff.
Do you just put the piston at TDC so the valve does not fall down into the cylinder?
Yeah I have heard of that way also.
I just talked to my buddy and he knows a guy that would hook me up on head porting so I think we will just pull the top end apart.
Looks like it will be a three man job, one on the cam, two on the top end and exhaust
If you're going to go with a cam kit... and if you're not on a budget. Go with an XE Grind. I love my cam. I replaced my entire valvetrain and paid like $880 in parts.
Here's what I did (finished last week)
XE 230/236 $260 (thunder racing)
Comp 612 Valve springs $110 (combination motorsports)
Hardened pushrods $25 (combination motorports)
Gaskets ~$50 (discount auto)
Timing chain $40 (GM dealership)
Tuning $65-75 by pcmforless or madz28 (or free for me since I tuned mine myself)
Pro Mag 1.6 rockers $160 (summit)
Here's my dyno graph with this cam from today: http://www.fuelslut.net/hosting/uploads/Dyno.jpg
Ryan
Ryan
Thats with headers?
http://www.angelfire.com/nj4/96blackws6/Dyno_4.bmp
is without only pulling to 5450 on a tune for a 112lsa cam running pretty damn lean. I'm hoping for numbers like hers. More actually since i'm going long tubes. But you get the idea
Let me know, cause I'd love to save nearly $200 on them
Ryan
Ryan
I assume I will need a TB also since I plan to at least port match and will have LT's and all???
