Throttle body Air Foil
Re: Throttle body Air Foil
Dyno test of an air foil on an LT1:
Drivetrain Modifications #4
2.4 peak HP
Dyno tests of other popular mods:
WS6.COM LT1 Trans Am
2.4 peak HP
please make sure u secure the screw/s so it does not back out.
A member on corvette forum had one spit out its screw and it went in to join a piston for a lil while... it was like metal hamburger in there.
Larry (Popo8) Co-owner
LTXtech.com
LTXtech.com
Oh thanks everybody! I tighten it down good but I think I will be rechecking it before I start driving it again. Thanks popo8!!
Yeah...if you stripped it, then best to remove it and get another one. You also need to make sure that shavings from the threads don't get into the engine(if possible). That may involve taking off the throttle body and removing the airfoil on a workbench. Then you can turn the throttle body upside down to make sure any metal gets removed from it.
Next time, use some blue thread locker on the threads and snug it up tight(no He-Man like force needed).
