Throttle body questions...
Originally posted by Hawk350
Will the 58mm will be ok for heads and cam or too much?
Originally posted by gamecockfan04
OK. If youre porting the intake 52mm or 58mm will work fine. Basically the price difference is the Brand and metal type their made from, but either brand will work fine.
That should probably add close to 30 to 40hp
With all of that which you are having done and if you get some 1.6rr and a CAI you could probably get close to 350-360rwhp. I really dont know much about the 230/236 cam, but based off of similar cams I think thats a good estimate. I also believe with the 230/236 youre going to need to get your comp reprogrammed. Good Luck!
