Throttle Bypass Mod, does it really do anything?
Old 10-12-2003, 01:20 PM
  #16
Black_Z28's Avatar
It works in the same way as Carb heat too. Like in a air plane. It heats up the air coming in through the carb/TB. This also richens up the mixture.
Black_Z28 is offline
Old 10-12-2003, 01:21 PM
  #17
HM Murdock's Avatar
Not there, that is a "hot" line, not a line of post-radiator coolant, it is coming out of the heater core which comes out of the flow towards the radiator.
HM Murdock is offline
Old 10-12-2003, 02:08 PM
  #18
Raptor1's Avatar
Originally posted by Cerwin Vega Fan
I thought coolant made it cooler?
It's a relative thing. If you take the time to look at Brent's web site and the tests he did on the TB bypass, you will see that the TB temperature was ~100* vs. a coolant temp of ~180*. BIG difference.
Btw, routing coolant through the TB to improve emissions is only ONE reason GM did it. There are other's, including driveability. Warmer air also = slower perceived throtle response, which = better driveability (from a grandma point of view )
Raptor1 is offline
Old 10-12-2003, 02:35 PM
  #19
Seal's Avatar
the coolant isnt so cold i recc u dont touch the coolant when its hot :P
Seal is offline
Old 10-12-2003, 06:33 PM
  #20
revtime's Avatar
I,m sorry guys but I wanna see where you read that GM routed hot coolant through the TB to help emissions.
I have been wrong before lord knows but I just don,t believe that was it.
Why didn,t they run it through the base of the carbs if this helped? It just don,t make sense.
Superchargers and turbos benefit greatly from intercoolers which I can guarantee you don,t heat up the intake charge.
It goes against everything we have learned.
revtime is offline
Old 10-12-2003, 06:50 PM
  #21
Seal's Avatar
it doenst use liq that absorbs the heat from the engine tho...it uses air... the way radiator helps keep the coolant 'cooler'
Seal is offline
Old 10-12-2003, 07:46 PM
  #22
crAzy95z28's Avatar
hahaha...well to late..i touched that **** on accident and gave me a chemical burn..and it was around 220 degrees!!!
crAzy95z28 is offline
Old 10-12-2003, 07:57 PM
  #23
Steve0's Avatar
I dont have any GM documented proof, but think about the old carbuerated cars and the heat riser valves that directed hot air off the exhaust manifold into the intake to help wiht emmissions. Routing hot coolant through the throttlebody in ways does the same thing.
Warm air would help the engine get to temperature quicker, and hence burn cleaner.
Steve0 is offline
Old 10-12-2003, 08:01 PM
  #24
Mir Hussain's Avatar
Come on guys, It was design to prevent TB to freez so it wont get stuck in some freezing temp!
Carb have totally different world then Modern EFI engines!
Mir Hussain is offline
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
R@mpage
04-20-2015 10:02 AM
97Z28Muscle
02-06-2015 10:44 PM
RedLineRev
01-23-2003 03:51 PM
Quick Reply: Throttle Bypass Mod, does it really do anything?
