Throttle Cable
Throttle Cable
After getting the car going again I am throwing a code stating that the TPS voltage is too high. I have done some reading explaining notching of the sensor to adjust the voltages. However, there have been statements about having to adjust the mechanical linkage so that at WOT the butterflies do not surpass 90º angle. When WOT the cable appears to be too tight, and will pass the 90º mark. I cannot see any way to adjust the cable to be looser. Any help is appreciated, and thank you in advance.
08-24-2015 06:41 AM
detroitmuscle
07-31-2015 04:21 AM
88IROC_Z
07-22-2015 11:38 PM
