Ticking
Old 04-23-2006 | 07:34 PM
Sgt. Spuds's Avatar
Ticking
Heres a video of it, WTF is it? Lifter Tick? Deffinatly not rod knock.
http://home.mchsi.com/~strang5/Tick.wmv
(right click save as please)
Car was ~210degs in that movie. Its worse on cold start up, almost a sewing machine noise. It has NEVER done this before. When it is worse is if your in high gear ( say 5th or 6th at like 40-50mph ) and your just going along idleing on flat grounds, and you come up on a hill, and your just gonna forgo downshifting to maintain speed, and the motor lugs a bit, thats when it makes the noise bad...
Im thinking its something in the valve train, but I'm not too smart.
Old 04-23-2006 | 07:53 PM
foxbat's Avatar
Re: Ticking
mine does something very similar at cold startup then goes away as the motor warms. i hear it again if the engine is under load. my budd who's a mechanic siad i have a small exhaust leak somewhere. i noticed it right after i had my cat-back installed. i think they banged something and opened up a leak probably from the exhaust manifold gasket.
Old 04-23-2006 | 07:56 PM
Sgt. Spuds's Avatar
Re: Ticking
Well, IDK if thats good news or not. Could My headers just be loose? Note I don't have stock manifolds.. I also am running 10w30 Mobil One Fully SYN. I was told to add stop smoke to the oil, in order to try and hide the noise if its in the valve train..
Old 04-24-2006 | 08:24 PM
foxbat's Avatar
Re: Ticking
could very well be a loose header. check all your bolts and listen around that area for the ticking. also look underneath for black soot marks. a telltale sign of exhaust leaking carbon.
Old 04-24-2006 | 09:43 PM
Bud M's Avatar
Re: Ticking
Check for a loose sparkplug.
Old 04-24-2006 | 10:23 PM
A2GrLT1's Avatar
Re: Ticking
how long ago did u install your headers? I know a week or two after I installed mine, my car started ticking as well. You could try and reinstall them with new gaskets. Its worth a shot. Search around the forums and you'll find which gaskets people use.
Old 04-25-2006 | 06:52 AM
Sgt. Spuds's Avatar
Re: Ticking
The BBK's have been on for over a year, possibly for the whole length of the cars life, I'll be sure to look Thanks
1slow93z28
09-01-2015 06:22 PM
94Z28LS1toLT1
04-30-2015 05:19 PM
importkiller94
01-17-2015 09:03 PM
sc93
04-04-2003 02:47 PM
Chris91Z
03-25-2003 02:24 PM
Quick Reply: Ticking
