ticking from rear after lca's and torque arm
I posted this about a week ago but I didnt get a reply. I installed a Spohn torque arm and Spohn LCA's last week and now I have a "ticking" noise from some where in the rear end. It is related to speed because the ticking gets faster as the car speeds up. also it goes away immediatly when I hit the brakes. I have already ckecked the pinion angle, sitting right at -1*, and re-greased all the new bushings. I also replaced the shocks in the car today. I have already ordered new poly bushings for the panhard rod and rear sway bar (heard that might fix the problem). I do not believe that it is in the ring and pinion gear because I had it checked out about 3 months ago and it was fine (different problem) I'm thinking it might possibly be the u-joints, but I'm not sure.....any other suggestions?
Fullagar
Sorry about the long post.
Fullagar
I had the same ticking noise .It is slow when you are driving slow,and increases with speed.Found out it was my tires.Have your car put up on a rack,and spin the tires slowly and look for nails.(I had my car checked for this 4 years ago including bearing checks and everything,and the noise didn't go away till I got new tires.)Hope this helps.
