Timing gear for '95
Re: Timing gear for '95
Depends if you just want a stock gear, LT4 heavy duty or a double roller like the cloyes 3145. I have my stock set if you want it. For the double roller, you'll have to get an electric waterpump. Do some searching and you'll find what you're looking for. Welcome to the site.
one more Question i purchased a timing gear from jegs but it doesn't have the water pump gear on the back if i were to buy an electric water pump would i be able to use my new gear
it is a blue racer and my dad bought it thinking it would fit but when it got to my house it wasnt the same i dont know about how well it would line up the chains have a differnt thickness would that cause ne problems
If it's part number 270-WG805, then it probably won't work since it says it's for big block chevys. If you have the stock LT1, then it's a small block. If you're working on the car anyways, most people would suggest upgrading the timing set to a double roller and installing an electric waterpump anyways. The chain will be more reliable and the wp will net you about 10 rwhp and should keep you cooler in traffic.
10-31-2016 11:09 AM
Lt1son
12-31-2014 01:35 PM
ChrisFrez
12-15-2014 03:09 PM
1LEThumper
07-14-2003 12:45 PM
