tires and rims
tires and rims
Well i have stock rims, what is the biggest size BFG DR's that i can fit on them,
Also what are the efects if i where to buy 17 in rims just for the back what are the biggest tires i could put on those\
PS getting 3:42 gears and 3000 stall
The only size BFG makes in 16" Drag Radials is 255/50-16.... so that's one answer.
If you go to 17x9 or 17x9.5" wheels you can use the BFG 275/40-17's. With 17x11 wheels you can run 315/35-17. Those are the only two sizes available.
