Top speed
#18
Actually....the car with higher weight would have more rolling resisitance.....correct due to the effect the weight has on the tires. But of course.....drag is the largest factor.....that is quite obvious.
Joe
Joe
#19
Originally posted by FireAm94
If you wanna do a search on the board you'll find a bunch of posts about the speed limiter and stuff. Fbody.org no longer has the info about it so....
Joe
Joe
Reminds me of one of the few math jokes that I know. There are 10 kinds of people in the world, those who understand binary and those who do not.......
Rich Krause
#21
Originally posted by OldSStroker
Nope, weight doesn't play much of a factor at all in top speed.
I remember having a similar debate with an fbody owner who claimed that a stock neon SRT4 had started pulling on a LS1 topend. His justification, they don't have as much HP but they are lighter. Of course we put an end to that with the good Sir Newtons law and a quick rehash of drag being proportional to velocity squared.
Yeah top speed is in the 150s, only gone 145 myself and because of the handling I don't care to again unless I make it up to Pocono on one of their open days. I already did ~ a 1300° at 100mph with someone else driving and they had to do an emergency lane change, not fun.
#22
If you're talking theoretical top speed...that's one thing. This whole thing started from a question about what the top speed of his z is. Do you guys consider the theoretical top speed to be the top speed? I don't know of any places besides the salt flats where you can get anywhere close to the theoretical top speed of an fbody. Thank god for common sense.
Joe
Joe
#23
Joe
Joe
Rich Krause
#25
Originally posted by Canadian z28
So do i have a 110mph speed limiter in my 95 Z?
#26
Originally posted by KeVMaN
people that got the crappy ones w/ out z rated tires and the 110mph speedo have speed limiters. Simple tire swap and pcm adjustment and they are the same as the other ones. thats why...
Also, I've had my 155 MPH speedo pegged, and still accelerating (my 159 MPH gorverner was removed). It still felt smooth nice and smooth.
#28
Here ya go....
All cars that came with stock touring tires (Good Year Eagle GA 235/55R16) were speed limited to 108 MPH. In addition, they got a 115 MPH speedometer. Cars opting for the QLC package (Good Year Eagle 245/50ZR16 GS-C tires) or the QFZ package (Good Year Eagle 245/50ZR16 RS-A tires, available in 1995 and after), automatically got the 155 MPH speedometer and did NOT have a speed limiter. This is because GS-Cs and RS-As are Z-rated for speeds over 165 MPH. Any car leaving the factory with a Z-rated tires, should also have the 155 MPH speedometer and no speed limiter.
That came from.... http://ls1.divetx.org/4thgenfaq.html
#30
Are you talking about theoretical top speed? I don't think so. I'm not talking about the listed top speed.
Here theory and observable fact get together: power available = power required. Try it, as has been suggested. It works.
If your car goes 150 with the power/gearing/drag it now has, note that rpm. If you can increase power at that rpm and somewhat above that rpm, your car will go faster, all else being equal. 10% more rwhp wil equate to about 7mph around 150.
As far as how fast an f-body has actually gone: a gen 3 with the long 'Bird nose and upwards of 1400 turbo'd hp as topped 300, but not without years of work. So, theoretically and actually, an F-body can go over 300.
Yeah, without gravity we'd have to change the method of getting the power to push the vehicle. With a reaction engine (eg. rocket or jet), we'd get a certain thrust or push. Strangely enough, tires produce a forward push or thrust which is transferred to the chassis thru the axle housing and control arms.
Oh, yeah, without gravity we'd need either aero downforce or thrusters to keep the f-bod on the ground.
But we digress...
