Torque Converter Change
Can someone give me the info on torque converter change on a 94Z. With the electronically control transmission what must be done if you want to put in a 2800 stall. Can the PCM be tuned for this so that the trans still works the way it should. Someone told me they thought that it would be aproblem and it would think it was slipping all the time. So what's the real scoop
armedtrigger
02-24-2015 08:30 PM
