Totally confused. What does this mean?
Old 10-28-2003 | 02:10 PM
ead94z28's Avatar
On freescan my MAP is reading .395 and my BAR is reading is 1.033. The MAP volts are 1.55. These are idle readings. Compared to injuneer's sensor page, these don't make a bit of sense. Please help!
Old 10-28-2003 | 02:13 PM
turbo_Z's Avatar
since the BAR reading comes from the MAP sensor... im gonna bet your MAP sensor is bad. when you blip the throttle.. does the MAP reading increase any?
Old 10-28-2003 | 02:19 PM
ead94z28's Avatar
I hit the throttle and it increased slowly from .395 to .200 and so on. The MAP is not coming up in the trouble codes or anything though. I have been reading that 9.5 as norm for map. Seems I'm way off.
Old 10-28-2003 | 02:28 PM
turbo_Z's Avatar
yeah that sounds like a bad sensor for sure unless you some how arent using freescan correctly so the readings look funny.
Old 10-28-2003 | 02:30 PM
ead94z28's Avatar
I think I'm using it right. All the other readings are fine, except for MAP an BAR.
Old 10-28-2003 | 03:04 PM
Re: Totally confused. What does this mean?
The readings you are getting appear to be some multiple of "pascals"...... its just the way they are showing the decimal point that is odd.
Normal barometer (BAR) is 103 kPa. That would appear to correspond to BAR = 1.033...... or 103.3kPa. MAP at idle with a stock cam should be about 1/3 of BAR, so I would expect to see 34 or 35kPa. Your reading appears to be 39.5 kPa.... or a shade on the high side, by not irrational.
A MAP voltage of 1.55 corresponds to roughly 37 or 38 kPa, so it appears your sensor is putting out fairly normal readings. Just that the idle MAP (remember BAR-MAP = vacuum) appears to be a little on the high side.... or vacuum is only 18.5"Hg, where you might be looking for 20"Hg.
Old 10-28-2003 | 04:25 PM
ead94z28's Avatar
Thanks injuneer and turbo_z for your replies. I'm going to do some cruising with the laptop connected and see what my readings are also.
Nayr
03-03-2023 09:34 PM
magman
04-15-2016 04:08 AM
gonzo275rltw
3rd Gen / L98 Engine Tech
09-07-2015 05:46 PM
gonzo275rltw
09-05-2015 07:26 PM
gonzo275rltw
09-05-2015 07:24 PM
