trans grinds when shifting.... What is it?
When I go to take off it grinds. If I give it more gas while letting the clutch out, it grinds worse. I have to let the clutch out really slow and leave it at like 1500-200 RPM. If I don't let out slow, it will grind. I am thinking t/o bearing. What else could it be? Clutch grabs good when I take off. It's like I have to pop the clutch. It's not chattering, it's a grind. Coming from the trans... I'm stumped.
Re: trans grinds when shifting.... What is it?
that doesn't explain how it grabs so good once it's engaged though... I'm thinking I need a new clutch kit, but I can't figure out what would cause this. I've never seen anything like this before. Anyone else have a suggestion?
