trickflow heads..the two center spring seats dont fit...???
On both heads. i cant get the spring seats onto the two middle spots. its almost like they are a bit smaller..any reason for this?
Is the interference with the center head bolt; if so it's not uncommon. You can grind down a small portion of the seat to get them to clear the head bolt.
no..the ACTUAL machined area is smaller in size..however that is interfering too. When I put the spring in any of the other ones without the seat in it theres noticably more room. And its the same on both heads.
this might help. check out the specs on the spring pockets. it says somthing about i.d. spring locators for the center 2. i bought mine assembled.
http://www.trickflow.com/product/che..._lt1_specs.asp
