Trouble finding ARP Waveloc Part#
I already ordered a set of "Waveloc" rod bolts (ARP134-6005), that turned out to be NOT Waveloc. I understand that Waveloc is only offered in the Pro and up levels. When placing an order at any of the websites that offer this part, how do I specify that I want the Waveloc kind? Or, is there a specific part # for LT1 Waveloc?
This is where I am looking: ARP Connecting Rod Bolts, Chevy | Northern Auto Parts:
Re: Trouble finding ARP Waveloc Part#
It does not say that 6005s are wavelocs on that listing. The wavelocs are listed further down the page. IIRC, I used 6403s. You might get other input to verify.
Thanks again! Gonna go ahead and order a set of those.
Still need to pick out crank and main bearings. If the machine shop guy said the crank was turned .010" under, does that usually apply to rod and main journals or just rods?
Sent from my SCH-I800 using Tapatalk
"pink" rods refers to a better prepped forged rod GM used periodically over a few decades. They have a machined flat on the top of the rod cap. Powdered metal rods do not.
I can come up with pics if I need to.
If you have pink rods I am sure the basic SBC part number will be fine but I am sure that at least in one style of rodbolt from ARP the PM rods have a separate PN.
On the big ends of the rods, you see the machined surface, on that there is a little swab of pink paint stained a bit brown by years of dirty oil.
I have known a number of colorblind folks and I think red variants is the most common to have trouble with.
