true dual ideas
true dual ideas
I was Thinking about the true dual setup but I really want to keep it as quite as possible should I order 18" bullets or 12" or is there any other mufflers that would be better? By the way I am running two 3" with an H-pipe for lower end torque
Originally posted by pelebkf
The only muffler i see in jegs that is 30" is smithy's mufflers and they are for 2" only. Is there any other mufflers that I am missing
summit has 30" smooth bullets and also chambered mufflers, but they are expensive. here is a link to them in a 20" http://store.summitracing.com/produc...earchtype=ecat
i dont know why the 30" arent on the website, but i ordered them out of the catalog.
dual 30" on a 3" true dual exhaust was still pretty damn loud.
now i have mufflers from http://www.bulletperformance.com/ (my local exhaust guy is a dealer)......they are round 4" outer body mufflers, with 2.5" straight through center. they come in 16" and 20".
setup is 2.5" true duals, h-pipe, under axle, 16" mufflers on each side, then tips.
its about as loud as the typical catback on a stock car......youd never guess i have longtubes and true duals.
hey got_hp? do you have any pics of your system? I would love to see the under the axel set up. do you have any problems with it? can you let the rear hang down if your car is on a lift? mine seems to be on a lift often getting better of course!
i havent had any issues hitting anything at all.
the axle would rest on the pipes if i put it on a body lift.............so before the rear axle i had a 2bolt flange installed on each pipe, so before putting the car on the lift, i can easily unbolt the rear section of my exhaust.
this also allows me to easily remove it at the track to run true duals with no mufflers dumping at the axle.
You said you wanted it as quiet as possible. Make sure you even want the Bullets first off. They are going to be LOUD. I love mine, but the sound might not be for everyone. Look into Spintechs, Flowmaster 1 chambers(still is gonna be LOUD) or something. Isn't the Borla XR-1 or something a true dual possibility?(Even though I hate Borla exhaust.
Well I know I really want true duals and I want them as cheap as possible. would the morso twisters be comparable to the spintechs because I know that they do not have any wool or fiberglass packing in them. I was also wondering if the 18" bullets are longer in the muffler or just the pipe.
I continue to hear that the DynoMax Ultra Flow (standard sized, not bullet) are amazingly quiet considering their flow. In some tests I've seen online, they flowed better than no muffler.
If you could fit two of them under the car, I'd say they would fit your requirements pretty well!
Like JSK333 said, the Dynomax Ultra Flow's may be a good selection. I'm glad he said those, b/c I forgot about them. They may be the mufflers you are looking for.
Yea I have seriously considered the ultra flo but they are about 100/muffler. Would those morso twisters be comparable or would these be louder than bullets. they are life 50/muffler which would be okay.
