True duals w/ aftmkt. torque arms?
OK, for those of you with true dual exhaust, what aftermarket torque arms are you running. Do you have any pics of your setup? I'm in the planning stages of my true dual project. Don't say get a catback.
I have the H-pipe, but stock TA.
Now there is guy named Ryan Ahart who had the same true duals I have, but was running an adjustable BMR TA.
On a side note, have you thought about the driveshaft loop?
I am running a Jeg's Loop for 82-02 Fbody, was about 35 bucks.
Ryan used a BMR loop, but had to modify it to get it to work.
Thanks for the info. I'd like to eventually get a TA that mounts to the crossmember instead of the tranny. I think it can be done with enough work. And about the DS loop(s), I've thought about it, but not too seriously. I know I'm going to install one or two, but I figure if I can't find one to fit just right, I can make my own.
Spohn TA w/ duals
You can see from the Spohn TA front mount that the car used to have a Y-pipe and the 4" Mufflex, hence the "dropped" mount. I need to get a "straight" replacement mount and maybe save a few pounds.
Originally posted by Injuneer
Spohn TA w/ duals
Spohn TA w/ duals
There is no "science "in my exhaust.... I just copy from cars that I know "work"....
The headers are "modified" AS&M's with the collectors pointing straight back. Originally, I had a dual cat Y-pipe, with a Mufflex 4" catback. The cats were flanged so I could drop them out for the track. When the cats dropped out, I replace them with 3" Borla XR-1 shorties... the mufflers you see on there now. I just copied the setup directly off George Baxters 30th SS (9.04@155mph).... actually I bought the headers of him when he switched to Hooker LT's.
When I had the Gear Vendor O/D installed, the Y-pipe didn't fit any more, so once again, I copied George... I figured if its good enough for 1,125HP its gonna be OK for my engine..... and just eliminated the Y-pipe and the catback. So it was running with nothing but the mufflers bolted to the collectors.
Then the local track decided that ALL cars had to have exhaust systems, including mufflers, and the exhaust had to end behind the rear edge of the door, so I had Mufflex bend me up a couple of "tailpipes" that I could clamp turndowns to. I also have an extra set of turndowns with "noise cones" in them, because the track (E'town) also has a 90dB @100' noise limit, under full power.
I never considered an H-pipe or an X-pipe because I always just piggyback off George's experience, with literally hundreds of engine and chassis dyno pulls, and he is still running a simple muffler on the collectors on what is now in excess of a 1,300HP setup. I think he is now using 5" mufflers though....
I've got some dyno time scheduled for next week, and we're gonna play with the exhaust a little to make sure it isn't a problem.
Thanks for the (as usual) informative reply Do you have any soundclips/movies of your dual exhaust setup? Did you have to relocate or shield your fuel lines? Was there anything else you had to modify or clearance to make your exhaust setup work? Also, what do you think it would sound like if I used bullet mufflers located closer to the dumps? Where can I get some more info on George Baxter's car, does he have a website or something? Thanks again
I have true duals with a spohn torque arm. The torque arm is for long tube headers. Then I have jet hot headers into an x-pipe which crosses through the torque arm, then I have two bullet mufflers on and then both pipes are run over the rear axle and come out the back. Looks very nice and a ton of ground clearance, no issues at all. Randy
I have pics of them, but they are not hosted and I will need to email them to you. If you want to post them then you can. It is a very nice setup. I will email them to you tomorrow, as I don't have my camera with me right now.
G. Baxter
There are a few pictures of it on one of my pages:
Friends' Cars
I like the one with the wheels 3-ft in the air....
There is also a video that I took of his 9.04 second pass on the F-Body Hideout website.
You know I have been debating on whether to keep my "dual" exhuast with no X or H pipe or put on my Lowbaks with an X pipe.
Injuneer, you just convinced me to keep the dual without crossover setup.
I may stilll use the Lowbaks but just straight out with a section of pipe to get the mufflers closer to the rear end and then turndowns cause I like em.
carguyshu
01-22-2017 11:19 AM
