TRYING TO IMPROVE SPEED STAGE 2 CLUTH? other suggestions??
Old 11-20-2010 | 01:59 PM
sashas0cal's Avatar
Lightbulb TRYING TO IMPROVE SPEED STAGE 2 CLUTH? other suggestions??
Hi I'm currently looking for ways to increase HP nd torque I was advised to upgrade my clutch to a stage 2 ...is this a bad idea? Nd helpful suggestions to increase speed is greatly appreciated
Car details:
Camaro conv. Z28 manual tran
LT1
170,000+ miles
Removed cati
Exhaust system
Changed air intake
Engine mod suggestions would be helpful too thank u
Old 11-20-2010 | 03:14 PM
Re: TRYING TO IMPROVE SPEED STAGE 2 CLUTH? other suggestions??
Changing your clutch won't produce more HP or torque, unless your current clutch is slipping badly.
I'd suggest you split this into two separate posts - one in the "Drivetrain" forum regarding the clutch, and the other here on LT1 Based Engine Tech, regarding the engine upgrades.
To get meaningful answers regarding the engine upgrades, you have to provide some sort of indication of your budget and your goals for power, both short range and long range. Also provide details of the "exhaust system" and the "air intake" you apparently already installed.
DirtyDaveW
03-15-2015 07:01 PM
carl.froehlich
03-13-2015 12:38 AM
cyteone
02-07-2015 06:04 PM
importkiller94
01-17-2015 09:03 PM
92ragtop
12-27-2014 01:56 PM
Quick Reply: TRYING TO IMPROVE SPEED STAGE 2 CLUTH? other suggestions??
