Two thumbs and a big toe up for PCMforless!
#17
Better luck? Luck is luck.
Power? I doubt it.
Ed and Brian both have plenty of experience progrsmming for the most popular combinations.
If you need more programing or reprograming, then I guess I'd go with the least expensive, but I really doubt that Brian would change much unless you are actually running too lean or rich.
Best bet is to have your pcm dyno tuned if you get a chance. Mail order is not custom tuning. Close maybe.JMHO
Power? I doubt it.
#18
When I had my pcm done the "mail order" way, it had too much timing almost throughout the whole scale..Luckly, there was a guy that has Tunercat, and hooked me up....Had rough idle, and you could actually smell gas through the fumes....
#19
Can you still use LT1 Edit after sending your PCM to pcm4less? I'm getting ready to bolt on the LT4 conversion, should be here today, and have LT1 edit, was going to try and take a crack at it, but wondering if I should go pro tune, then tweak it w/ my edit program.
thanks.
thanks.
#20
thanks.
thanks.
09-18-2015 03:46 PM
cmsmith
08-20-2015 07:57 PM
NewsBot
08-03-2015 02:40 PM
