Ugh, more oil pressure woes, pressure is dropping at WOT now..
Old 11-10-2008, 03:03 PM
  #151
Jditlfm's Avatar
back from the dead. Did you ever get this fixed, or have any problems resulting of the oil pressure dropping?
Jditlfm is offline
Old 11-10-2008, 04:56 PM
  #152
MeanGreen97Z's Avatar
Hey bro... he rebuilt the motor. Check his sig that lists his 355.
MeanGreen97Z is offline
Old 11-11-2008, 11:21 AM
  #153
krillformula's Avatar
Just read the whole thread, some very good information!
He said in his second post that he bought the 355 from a member here and thats the engine he had oilpressure problems with!
krillformula is offline
Old 11-11-2008, 03:39 PM
  #154
redemn93's Avatar
the motor is perfectly fine. oil pressure problems were due to wrong info on how much oil to put in the new pan. runs a little less oil now and pressure is perfect. motor is strong. i should know, i helped put it together. i forget which pan it is. researched showed it to be a common issue with that pan.
redemn93 is offline
Old 11-12-2008, 09:53 AM
  #155
Moderator
Javier97Z28's Avatar
No, it did not require a rebuild because of this. As said below by my friend, in this case it was just a matter of running 5.5 quarts instead of 7 quart. I was getting excessive windage with too much oil in the pan.
The 355 that this thread is about is still the one that's in my car to this day.
Werd!
It's a Milodon 30909 I believe.
Javier97Z28 is offline
HectorM52
07-30-2017 11:46 AM
Dmonty
06-02-2015 11:19 PM
transam_388
03-15-2015 11:53 AM
captcorvette
03-07-2015 12:37 PM
WildRidez
01-16-2015 03:10 PM
Quick Reply: Ugh, more oil pressure woes, pressure is dropping at WOT now..
