Ugh, more oil pressure woes, pressure is dropping at WOT now..
#91
Re: Ugh, more oil pressure woes, pressure is dropping at WOT now..
Just got home... gonna go pull some oil out of her in a bit.
String.. I know it's a long thread, but I posted a little earlier that I have a new sending unit as well as a brand new mechanical autometer gauge installed. Both duplicate each other's readings.
#92
Karl,
In this picture you will notice the reading on the dyno of VACUUM is -2.1, there is even more power in that motor if you can get rid of that. I like to see around -1.0 or less. On a NA motor your looking at 20-25hp right there.
BTW very cool site and video
Bret
Bret
#93
Originally Posted by Javier97Z28
I've got too much cash in this bucket to give up on her now.. fortunately I'm not scared of wrenchin'.. I think my buddy redemn93 is gettin' a little worn out on it tho lol.
I've told my wife I want to be buried in it when I'm old and gone
I'll have the pump tomorrow
#94
Originally Posted by SStrokerAce
Javier,
Karl,
"You see the pressure diving to 20psi and I'm thinking, "stop the dyno pull!!!!!" Ahhhh!!!!"
Pansy.... wait till you do 3 pulls with the pressure going down to zero and you don't flinch! .............
Bret
Karl,
Bret
Karl
PS: also the full "Blackout" web site is days and days of enjoyable reading and great entertainment. Anders Envall the owner/creator is a legendary gear head. www.blackout.nu
#95
Yeesh.. I shoulda just listened to you guys earlier.
I dropped approximately 2 quarts.. so that should leave about 5.5 quarts total in the system...
Oil pressure stays up! At full tach out with my limited RPM range right now (shifting at about 6200 rpm) the pressure needle gets to just under 80psi before the shift.
Oil pressure is at follows (only warm readings given as those are the ones that matter)
At idle in D: ~38-40 psi
Anywhere at cruise: 60psi
At WOT climbs to 80 psi, then falls to a little over 70 at the shift.
I'm going to put a regular street filter back in.. with only 15 miles on it the oil that came out was pretty gross from the Wix filter... I think that will also bring my pressure down a tad bit, along with going back to 10W30 oil.
WOT launches with the nose climbing in the air I did not loose pressure either, the rear baffle seems to be working well.
Thanks to EVERYONE for all the help and suggestions. Does anyone think the additional RPM to 6900 will make a difference later? Or should I be ok now? IE, will it build more pressure with the additional RPM...
#97
Very good news. I'm glad you posted the result because I've been bird-******* this thread all night hoping to see the good news.
karl ellwein
karl ellwein
#98
Yea, I never planned on running my pan on full. Ill run it on the low mark knowing its got a deeper sump.
Edit: Thats awsome man
#101
Originally Posted by Daniel6718
so what pump did you end up with? and where you get it from?
any mods to it?
i need to fix mine now!
any mods to it?
Went from 7.5 quarts with filter to approximately 5.5 quarts system total.
I have the pump but I see no reason to install it at the moment. It's a Moroso 22125, 8.25" depth pickup.
#102
You think this will lay to rest the theory that the HV pump sucks the sump dry? You fixed your problem by putting in the stock pan capacity.
#103
Been following the post for s few days now and am glad you got it worked out. I am pretty much running the same system with the milodon pan and the Melling M55HV pump. A friend of mine just got done with my 381 stroker and I just drove it back home yesterday. It held 60psi at cruise and getting on it got between 75 and 80psi falling like you said a little on WOT shift and then shooting back up. It is running 10W30 with a bigger filter at 7 quarts at the moment. Was wondering if I should put less in like you have when I give it the next oil change at 1000 miles? It now has 150 miles on it since it's 100 mile change.
#104
The HV pump is just overkill since you seem to have a ton of pressure... but I'm glad that your lower oil level paid off. There is no need to run that much oil (7 qts) in a pan anyways. Next oil change just dump 5 qts in it and call it good.
BTW you'll want to change out the oil after some miles to wash all the assembly lube and junk out of the motor. I do about 2 filter and oil changes before I call the motor ready to roll and I'm a clan freak on assemblies.
Bret
Bret
#105
Originally Posted by quickSS
Man you got that right,. I cringed and put my foot to the imaginary brake pedal when seeing that. You have the seat time and cast iron stomach obviously. Call me a rookie and a pansy when it comes to this stuff. hahaha. In the video (you guys have got to down load that video it's fun gearhead stuff), I notice Lennart just calmly watching oil pressure dive dive dive.
Karl
Karl
Karl,
I was just playin with ya... you know when the oil pressure goes down like that you have to tear into the SOB anyways.
The video and the site is fun BTW. Thanks
Bret
