Ugh, more oil pressure woes, pressure is dropping at WOT now..
#106
Re: Ugh, more oil pressure woes, pressure is dropping at WOT now..
Bret.. am I going to hurt anything by running that much oil pressure?
After about 1k miles I'm going to switch back to Mobil 1 10W30 and a regular filter, maybe I'll have some pressure drop?
I've already changed the oil about 3 or 4 times btw.. I was experimenting with oil viscosities. This is the oil w/ the most WOT passes tho, so I'm going to change this one out then hold out for my 10W30.
I kinda wish I'd kept my stock pan now instead of wasting $230 on this Milodon.. but oh well.
#107
It doesn't hurt but that HV pump is beating on the distributor gear (oil pump dirve gear) pretty badly now anyways.
Bret
#108
So what you're saying is I should swap it to the standard volume or???....
I'd rather pull my intake manifold once every two years and replace my drive gear.. heh.
K, I'll exchange my Mobil 1 for some 5w30
#109
FWIW, I blueprint the pumps to have the max pressure that I am looking for and the idle low RPM pressure is set by my main clearances, the pump and oil viscocity. I like 40psi at idle and 55-60psi max along with the lowest grade (ie 0w-30, 5W-30) I can get to do that.
All gears can wear out BTW, the best is the composite gears but they don't come in the LT1 shaft size, but there are some ways around that (none that are cheap). The iron and bronze gears can both easily wear out.
Bret
PS Have a good Memorial Day!
Bret
#110
Cool Bret, I'll play around with viscosities and go from there. Maybe I'll keep that standard vol pump and whenever I get around to doing a bmr kmember I'll swappy swappy pumps!
Happy Memorial Day to you as well!
#112
Originally Posted by Daniel6718
so what was the reason that less oil helped your pressure? i dont thnk that would be my problem..
I don't know the details on your oiling system so I won't be able to help much
#113
think it would help with a stock pan? i have tight clearenced and a stock pump but it drops pressure above 4k....i run valvoline straight 30 weight and im in tx 100 degrees daily
daniel
daniel
#114
Daniel, do you not have the stock windage tray in there???
This symptom can happen if you have too little or too much oil in the pan, but if you don't have a windage tray (even the stock one) you can have this problem at anytime.
Bret
Bret
#115
yes i do...the oil pan has no modifications...i use a ph1218 truck filter and have the stock oil cooler(soon to be gone) and put in 5 quarts of valvoline 30 weight about every 1000 miles
#116
Daniel I'm not familiar with your setup...
Stock bottom end? Have you replaced the pump / messed with it at all? Proper height to the pickup tube?
#117
bret
#118
Like Asked above is it really going through that much or are you just adding it? That seems excesive...
#119
spun a rod bearing got it rebuilt by myself and a family friend mechanic tight...its a stock pump stock volume, pickup should be correct and was tack welded...and no i just run my car hard and i change it frequently...my freind flames me all the time but thats about every 6 weeks for me...
