Ugh, more oil pressure woes, pressure is dropping at WOT now..
Old 05-31-2006, 01:30 PM
  #121
Daniel6718's Avatar
Re: Ugh, more oil pressure woes, pressure is dropping at WOT now..
if the pickup is too high how could i check it?
Daniel6718 is offline
Old 05-31-2006, 01:32 PM
  #122
Moderator
Javier97Z28's Avatar
Well, in a stock pan situation I doubt less oil will help.
Assuming, the pickup is right, windage is on correct and at the proper distance, I'm at a loss on this one... what do the bearing clearances look like on both the mains and rods? I'm grasping at straws here..
Pickup height can be checked by putting some clay on the end of the pickup and placing the oil pan back in place. Stock pan, stock type pickup, probably 3/8" clearance is fine judging by what I've read. Put some tape over the screen to avoid getting clay shoved in there.
Javier97Z28 is offline
Old 05-31-2006, 01:35 PM
  #123
SStrokerAce's Avatar
Javier....
I was thinking we need to make a:
Javier Tranny Fund... help the guy out there are guys in Florida that need to race to. lol
Daniel, All I can think of with the rebuild and losing oil pressure..... hmmmm let me think about that one. Something is not right.... how did the crank look? What bearing clearances did you get on the rebuild?
Bret
SStrokerAce is offline
Old 05-31-2006, 01:43 PM
  #124
Moderator
Originally Posted by SStrokerAce
Javier....
LOL if anyone wants to sponsor me a free built 4L60E I've got a whole rear windshield that can be used up for the banner
Or a racing fund sounds good too I want to get some times outta this thing.
Old 05-31-2006, 01:47 PM
  #125
Daniel6718's Avatar
no (copied from my other post)
when i hit it i go to about 55-60psi and start to climb to 70 psi until about 5000 then i drop to 40 psi....i run valvoline 30 weight(reccomended by mechanic) with a ph1218 truck filter stock pump tight bottom end
the oil comes out fine...the clearences are tight, im only losing pressure at higher rpm
what is the stock spring supposed to release at? is there a spec on that?
  #126
1SlowFormula's Avatar
I wouldn't mind helping however I could
1SlowFormula is offline
Old 05-31-2006, 01:56 PM
  #127
Moderator
Originally Posted by 1SlowFormula
Let me talk to Frank and we can see if he can hook you up with a little something or other
woah sweet
Daniel.. not sure where the stock spring is supposed to release at. How tight it tight?
Old 05-31-2006, 01:58 PM
  #128
woah sweet
No guarantee's or anything, but it will probably cost you most of that rear window space...
Old 05-31-2006, 02:02 PM
  #129
Moderator
lol np man, I'm open to options and we can always bargain from there
Pro Race rebuild ftw
If he doesn't want do to that I'm a decent web designer too
Old 05-31-2006, 02:13 PM
  #130
Don't go there... hehehe
But, hey I'll keep that in mind if I get behind
Old 05-31-2006, 02:14 PM
  #131
Daniel6718's Avatar
they are a little looser than yours....
.0016-.0020 rods..
and mains were .0022-.0025
  #132
Moderator
lol k i'll stick with banner hopes
Old 05-31-2006, 02:17 PM
  #133
.0016-.0020 rods..
Daniel the looser clearances and stock pump should get you less presure, something else must be causing the rise, have you tried a thinner oil? the staight 30 is pretty thick for your car unless I am missing something...
Old 05-31-2006, 02:18 PM
  #134
Cool, hey I'm going to edit some of my posts above so this doesn't get crazy...
Old 05-31-2006, 02:26 PM
  #135
Daniel6718's Avatar
those clearences arent that tight....they are just looser then javiers
what are the stock specs and i could tell you what mine are for sure
is straight 30 that thick? what do yall reccomend?
daniel
Quick Reply: Ugh, more oil pressure woes, pressure is dropping at WOT now..
