un-tuned cam only record?
I have the comp xe230/236 cam and finally dyno'd her after 1.5 years of having it cammed. she put down 357hp and 364 tq! This was WAYYYY rich too, so rich it went off of the graph and i cant tell how rich it went. Also, i still have the stock rev limiter at 5800, and from what I've seen this cam pulls till 6300-6400 rpm, so who knows what i'll dyno after taking off the rev limiter and getting her tuned. lovin' my cam! Does anyone know what the highest stock tune cam only car has pulled? and again, the highest tuned cam only car?
Re: un-tuned cam only record?
Wow,
What have you done to your car?
That's amazing if your pulling those numbers... without even reaching the peak RPM's of that Cam.. I hope mine does just as well.
Dyno #'s don't mean a whole lot..especially if the #s are uncorrected. Don't mean to flame you or anything, but I'd rather see some track #'s
Can you post the graph anyways?
2. I doubt you have more in the car as far as rpm goes. With fully ported LE2 heads and that cam peak power was at 6000rpm, and with home ported LT1 heads and that cam I had peak at 5900rpm (this was before the LE heads). You could gain power fo sure by running 12.5:1 A/F.
I havnt gotten any track numbers yet with this setup, For the WHOLE time i've had this cam, I had defective comp "r" lifters, and i jsut recently changed them out with my stock lifters. New track times are on their way, but with my 3 defective "r" lifters the best i pulled was 106mph. dyno graph on the way
does anyone have a time with the 230/236 lol everyone ive ever asked has never gone to the track. i want to but i cant ever seem to get mine running just right and im bout to ****** the whole motor out n go thru it next month.
106 mph is what about 315-320 rwhp. I really fon't see an additional 37 rwhp from changing out the rockers, so I would guess you are still amking around 330-340 rwhp corrected, which is still good especially when its not tuned.
The extra power and tq from leaning it out would have been substantial. I picked up 30+rwtq from 2400-3000rpm on the dyno and I didnt play with timing (I had a little KR). I suspect trap speeds would have been 116-117mph if I was in the 383rwhp tune.
To just say "if your results are in STD so it means nothing" is not true.
SAE and STD are simply correction factors. Your STD #'s can be compared to anyone else's STD #'s because you both have the same correction.
It is the UNCORRECTED #'s that should not be compared.
More importantly...was brand was the dyno?
