Update new cam only lt1 times
#17
Re: Update new cam only lt1 times
Thanks to all of you folks that congratulated me. i've been recieving a lot of pms and emails. i will be out of reach for a couple of days i will be back Thursday. So if you ask a question on this thread or others and don't get a reply I am not ignoring you. Frank95z
#19
Awesome times their Frank.. your car is an aspiration for mine
My car has about 200# of raceweight over yours (no weight reduction), but damn, you've got 4 mph on me even with your smaller cam from before!
Aside from the good air, which I've run in with my times, any suggestions? How about shift points? My car shifts at about 6250 RPM, just curious as to what you wind yours out to?
#22
Wow your smoking some h&c setups I've seen on this site or at least damn near (assuming all the track conditions, sus. setup. ect.)!!! Great Job!! I also was trying to get a hold of Joe he posted a message on his message board explaining how buzy he is so I just gave up. Good luck though.
-brandon
-brandon
#23
chy20k Yes my cam is bigger than a 847 and yes i have stock thickness head gaskets. i was going to run impalas but decided to stick with stock.Javier I currently shift at 6200 but I believe once tuned this new cam will like about 6400. bdc Thanks and I hope to run a little faster before changing to ported cams. Frank95z
#26
Turbo Yes i'm going to dyno and tune in January. Harvey yes I have a stock bottom end it has never been taken apart. I had the heads off last year for a look-see and the cylinder walls looked new. My car has 74500 miles. Frank95z
#27
This goes to show that suspension and drivetrain mods really pay off to get 60' times like those. Then a little weight reduction and an excellent package of parts you're really movin. Good work Frank I hope to break 11's next season.
#28
96flame My car has stock shocks,springs,torque arm. i have both swaybars removed and an airbag in the right rear spring. I run at a well prepared sealevel track that is the key to good 60fts. the stock suspension is good as is. Frank95z
#29
