View Poll Results: Does your LT1 leak?
Yes and proud of it.
144
59.26%
No. And I hide sandwiches behind the intake.
85
34.98%
This thread is worthless. And I own a box of Kleenex.
14
5.76%
Voters: 243. You may not vote on this poll
Useless poll! Does you lt1 leak?
Old 07-25-2005, 10:42 PM
  #16
92/95TransAm's Avatar
Re: Useless poll! Does you lt1 leak?
does anyone have instructions on how to dimple the intake to make it stop leaking it has been bothering me for a while now
92/95TransAm is offline
Old 07-25-2005, 11:05 PM
  #17
orbitalshock2k's Avatar
No, but I'm looking for an excuse to take the engine apart so I can cam it.
orbitalshock2k is offline
Old 07-25-2005, 11:19 PM
  #18
DWray's Avatar
TTIWUSBMALT1!
(This thread is worthless unless somebody buys me an LT1!)
DWray is offline
Old 07-25-2005, 11:30 PM
  #19
Zack's Avatar
nope
Zack is offline
Old 07-26-2005, 12:05 AM
  #20
lt11997's Avatar
Originally Posted by LS1_03
My intake leaks, but it doesn't drip onto the ground. I'll solve that for whenever I do a cam swap.
I believe the back of my intake leaks as well but it's not even enough to notice on my garage floor.
lt11997 is offline
Old 07-26-2005, 12:06 AM
  #21
SantaCruz163's Avatar
Sure does
I'm 99% sure it's from the rear main. I'm an idiot for not changing it when I had the tranny out for my clutch change
I always have some fresh drops on the driveway in the morning. I should really post pictures of my driveway. From my oil leaking, to spilled oil during oil changes, tire spray, you name it; this driveway is all spotted up
SantaCruz163 is offline
Old 07-26-2005, 01:05 AM
  #22
Indelibility's Avatar
My engine is leaking from 3 different locations...the driveway is a mess
Indelibility is offline
Old 07-26-2005, 01:14 AM
  #23
jchevy's Avatar
Damn that waterpump drive seal . Its my only leak, and evey where I park I leave a spot about the size of a quarter.
I even took it apart and tried to fix it once. Man was I pissed when it was still leaking after all that work.
jchevy is offline
Old 07-26-2005, 01:21 AM
  #24
Z28Nut's Avatar
Had an intake oil leak - fixed under warranty
Pinion seal leak - replaced pinion yoke and seal, fixed leak, broke rear gear 2 weeks later. Now have a new 12-bolt.
tranny output seal leaked - replaced seal w/ new driveshaft twice, bent 1st al DS when tranny mount broke.
Now the only leak is the windshield washer tank.
Z28Nut is offline
Old 07-26-2005, 01:22 AM
  #25
JBird33's Avatar
Very small drip from the front main, and I believe its cause I switched to synthetic...actually seems to be getting smaller though, like perhaps the seal is breaking in to it....
JBird33 is offline
Old 07-26-2005, 01:33 AM
  #26
luckyou03's Avatar
small front seal leak, water pump leak and rear end drips a little
luckyou03 is offline
Old 07-26-2005, 07:22 AM
  #27
SmoothCruizer's Avatar
Leaky hear too..... im noticeing leaks or wetspots up by my heads..... hope its normal.... true lt1s leak from the intake i guess, mines wet back on top of the bell housing.... oh well right?
SmoothCruizer is offline
Old 07-26-2005, 07:26 AM
  #28
2000GTP's Avatar
No leaks from anywhere with 94000 miles. It kind of sucks though because I dont have a legitimate excuse to start tearing apart my motor or tranny yet.
2000GTP is offline
Old 07-26-2005, 07:31 AM
  #29
BlkLT1Z28's Avatar
i have a small leak from the low oil pressure sensor in the pan. It leaks very slowly from there. A new sensor is $20 so if I ever get it and fix it then problem solved. But the motor blew sooo.........I dunno.
BlkLT1Z28 is offline
Old 07-26-2005, 07:44 AM
  #30
kevm14's Avatar
No leaks from the engine at 160k. But it did have the intake leak fixed by the previous owner (my cousin actually) around 120k. The pinion seal weeps/leaks though, and my driver's side axle seal is starting to go. I just did axle seals on my other car, too!
kevm14 is offline
Quick Reply: Useless poll! Does you lt1 leak?
