View Poll Results: Does your LT1 leak?
Yes and proud of it.
144
59.26%
No. And I hide sandwiches behind the intake.
85
34.98%
This thread is worthless. And I own a box of Kleenex.
14
5.76%
Voters: 243. You may not vote on this poll
Useless poll! Does you lt1 leak?
Old 07-26-2005, 02:26 PM
  #31
neil350's Avatar
Re: Useless poll! Does you lt1 leak?
Ion,
If it sits for like a week or two you might see a tiny drop or so on the ground, how ever it doesnt really leak, it has a couple pots where oil has seeped but none hits the ground and if it doesnt hit the ground I dont care. Its a 13 year old car, the intake seal did leak at some point how ever because the trnny is caked in oil. But all SBCs leak or seep some way or another
Neil
neil350 is offline
Old 07-26-2005, 03:05 PM
  #32
ibanez6rg's Avatar
Mine leaks now after the cam swap. I think it's the rear main. Re-did the intake and that didn't stop it.
ibanez6rg is offline
Old 07-26-2005, 03:38 PM
  #33
JKDZ28's Avatar
Yup, I've got a few leaks...very minor though.
Doesn't show it on the ground really.
JKDZ28 is offline
Old 07-26-2005, 03:50 PM
  #34
JeffsWorld's Avatar
Yup, an occasional drip from the infamous rear intake oil leak
JeffsWorld is offline
Old 07-26-2005, 05:43 PM
  #35
96capricemgr's Avatar
I have a 96 Caprice cammed with 160K total and maybe about 90K or so on that motor no leaks exept maybe some slight timing cover wetness but never a drip.
A 186K mile Roadmaster Wagon, original engine best I know, the oil cooler lines leaked a little but an AutoRX application stopped it.
96capricemgr is offline
Old 07-26-2005, 05:57 PM
  #36
ArcticWhiteZ28's Avatar
yep mine leaks a tiny bit don't really know if its rear main, intake, valve covers, etc.
ArcticWhiteZ28 is offline
Old 07-26-2005, 06:11 PM
  #37
jtcz28's Avatar
Ya mine leaks too, small amount from the front timing cover/water pump
jtcz28 is offline
Old 07-26-2005, 06:17 PM
  #38
Johnnynsac's Avatar
Well it really depends. When I used regular oil it never leaked. Once I started using Synthetic oil it started leaking right away. I don't know from where.
Johnnynsac is offline
Old 07-26-2005, 07:21 PM
  #39
mattbailey's Avatar
Doesn't leak a drop since my cam swap, I had a few before though. I just took my time to make sure it didn't this time.
mattbailey is offline
Old 07-26-2005, 08:22 PM
  #40
b4c97's Avatar
timing chain cover, power steering line (somewhere), and blood when I change the plugs.
BARRON4406, that is the best pic yet.
b4c97 is offline
Old 07-26-2005, 08:55 PM
  #41
Z28WannaB's Avatar
Mine does not leak, its got 130K on the clock.
- Z28wannab
Z28WannaB is offline
Old 07-26-2005, 09:43 PM
  #42
phinger23's Avatar
i HAD leaks...not any more...i hate leaks.
phinger23 is offline
Old 07-26-2005, 09:54 PM
  #43
Valkyn71's Avatar
Mine always used to leak from the timing cover/pan gasket area, but i just put in a new pan gasket so hopefully that will be gone!
Also the differential leaks, POS.
Valkyn71 is offline
Old 07-26-2005, 10:02 PM
  #44
Frank89IROC's Avatar
Thumbs up No oil on the ground
but when I do oil changes, I notice a little on & around the starter, wipe it off. Never seems to make it to the ground though. Never add oil between changes.
Frank89IROC is offline
Old 07-26-2005, 10:41 PM
  #45
Silvershark's Avatar
New engine, no leaks.
Silvershark is offline
Quick Reply: Useless poll! Does you lt1 leak?
